Powerglide shifting problem, vacuum ?
So here's the problem in my 63 wagon {350/powerglide}, when the modulator line is hooked up I have no up shift, When its disconnected it will up shift then slip at full throttle, Idk its driving me crazy I changed the filter and modulator and its doing the same thing. I have the modulator line hooked to the back of the intake is there to much vacuum? , mind you this is my first powerglide
Do you have the throttle linkage from the power glide to the carb hooked up?
The vacuum on a glide only controls internal pressure, not shift timing. Is this glide a recent rebuild or an old unit ?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| The Following User Says Thank You to Crosley For This Useful Post: | ||
glideless (11-03-2012) | ||
The linkage is hook to the carb, the powerglide is an old unit it ran fine with my L6, I don't have the kickdown hooked up I just recently found the V8 linkage would this affect shift points? I do plan on going with a th350 when i get some extra cash you know how it is when you have a couple classics , Maybe my glide ready to take a dirt nap or is there still hope for it?
| Powerglide shifting problems | chanman45678 | Transmission - Rearend | 1 | 05-08-2011 08:22 PM |
| powerglide problem | nitro_baller4692 | Transmission - Rearend | 1 | 09-13-2010 12:05 PM |
| Powerglide problem | 58lincoln | Transmission - Rearend | 2 | 11-30-2008 08:46 PM |
| Powerglide - strange shifting??? | wolfeman | Transmission - Rearend | 3 | 08-18-2007 09:16 AM |
| Powerglide problem | WarWagon | Transmission - Rearend | 7 | 10-19-2006 02:17 PM |
