I've been thinking about trying to use my old
powerglide begind the new 396, but some questions arise. Orginally the pg was behind my L6. Can a 6cyl powerglide be made stronger by using 8cyl clutch packs? or are 6 and 8 cly versions completly diffrent? Second, I have this spiffy midwest 3k converter for a th350, Are there any kits to use a th350 converter on a glide? And lastly, Lets say that I can find an input shaft kit and can rebuild with the 8cyl clutch packs Could a powerglide survive behind and optimistic 450ft/lbs and 460hp with slicks, or am I daydreaming? I know a th400 would be a better choice but I miss my glide. Brandon <venturat> 1.82:1 1.00:1 |
Sky is the limit on what a powerglide can handle. The money you can spend is also. I am thinking the PG and TH series share the same converter. Have you tryed to put in on? I personally dont know all the particulars on building the glide to last, but with less than 500lb/ft you should be able to do it reasonibly.
chris |
Check Summit catalog. They carry everything you need to make your PG a fire-eater. Main things needed are a stronger input shaft and a steel clutch hub, both amazingly low priced. Also, like any other modification, put in a shift kit. There are many other mods you can do up to nd including a new high strength case but those are for the serious racer. Shaft and hub will do it for majority of engines. Use TH350 converter.
as the other guys tell you....money is the key factor.
A turbo splined input shaft is needed to run regular T-350/400 style converters. BUT it is not that simple. The pump must be modifed for a bushing for the turbo splined shaft or the converter built with a bushing inside that is not normally there! The 6cylinder glide should have a 1.82 low gear set. They are the weaker of the 2 gear sets the glide was built with. We have treated 1.82 gear sets with the cryo-genic stuff. Super cold treatment. This greatly increases the strength of the part. Tony
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I am running a 6 cyl PG in my son's '36 Pontiac 4-dr sedan. Double click my Avatar to see some photos of it. The 1.82 low gear is great for this heavy car. Tranny does great!
