Powerglide swap to 350 Turbo
I have a 1966 impala that I'm putting in a SBC 406, with a turbo 350. After removing the original 283 with the Powerglide, I'm having trouble getting the original Powerglide transmission crossmember to fit. Or maybe I should be asking the question, should it fit? Anyone know of aftermarket tranny crossmember that would fit? Also, are there any Driveshaft mods to expect?
Thanks Cixty6 |
I believe the TH350 is a direct bolt in check this article out.
http://www.chevyhiperformance.com/te...ide/index.html of course this resource says differently http://forums.superchevy.com/70/6463...wap/index.html But if it is not working for you then obviously you need to change something. You could fabricate your own pretty easily. |
Thanks for the info..
It Fits!!
With a good jack and some persuasion from the "olde hammer" the cross member slid up over the perch on the frame rail. Can we say " Happy " :0) Problem solved. Now with this 406 SBC and a TH350 pulling this Big hunk of Metal, I should have some fun smokin' tires. Wish me luck!!
Thanks Again.. Cixty6 |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| newer sbc 350 to older turbo 350 | yragat | Transmission - Rearend | 8 | 10-20-2007 07:52 PM |
| 350 turbo to 400 turbo swap in lemans?? | mtmniles | Transmission - Rearend | 8 | 01-24-2006 12:40 AM |
| 350 to 305 swap | 78Z | Engine | 10 | 02-06-2005 01:42 AM |
| Turbo 350 | 1980 Malibu | Transmission - Rearend | 14 | 07-27-2003 04:24 PM |
