Powerglide or T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 08:25 AM
B.A.M.F
Powerglide or T-350
so i have a 600+HP SBC thats going into a full weight 81 FireBird use is for street class maybe mod drag racing i currently have a TH350 but dont know if it will hold, what exactly is a powerglide trans. which is better ?
Old 07-17-2011, 08:57 AM
Overdriv's Avatar
Check here.
If you are going to run it on the street, in my opinion the three speed trans would be a better choice.
Drag race only, it's a toss up. The Powerglide can be modified to handle 600HP easily. Either must be matched to a properly sized and stall converter.
The powerglide is a bit lighter than a THM 350.
Old 07-17-2011, 09:26 AM
B.A.M.F
Originally Posted by Overdriv
Check here.
ok this is deff not going to see the street, the way this engine is build has been tailored towards the 1/4 mi putting a converter with a flash of 5500RPM behind it not trans brake as of yet the TH350 can take the 600HP if im correct or would a TH400 be the better way to go
Old 07-17-2011, 10:59 AM
If you are under 2700 lbs or so with you in it. Then a PG would work fine other than that a TH350 or a TH400 would be the ticket.
Either a TH350 or TH400 would do. Take less PF parts for a 400. But it is your choice. Takes more HP to run a TH400 but not much more.
Old 07-17-2011, 01:44 PM
B.A.M.F
Excellent thanks deff over 2500lbs so ill start inquiring into a custom build TH 350 specifically for what im looking to do thanks much
Old 07-17-2011, 03:01 PM
powerglid
where are you from? if***************
*****************************s break on it also.
Last edited by Crosley; 07-17-2011 at 03:30 PM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 07-17-2011, 03:12 PM
certified mechanic
powerglide or 350
i would have to agree a 350 will hold up if you have it build rite i know acouple drag racers and they both had powerglides in and made two passes on one and the other made 8 pesses before it blew apart going 80 mph. i would say a 350 you get more gearing for off the line for a jump on the other car.
Old 07-17-2011, 03:34 PM
B.A.M.F
lol no idea what this meant haha
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
musclecarsrock68 ;
welcome to Hotrodders.com
No sales , offers to sell or want ads in the main open forums are allowed.
Use the classified section or contact the member via the PM system if you wish to offer to sell an item.
Old 07-17-2011, 03:35 PM
B.A.M.F
i have to agree but only because iv never dabbled in the world of powerglides, most racers i know that use em love em but i get squeamish when i start preparing to spend money i wanna do it right once
Old 07-17-2011, 03:38 PM
Originally Posted by Crosley
musclecarsrock68 ;
Thanks, and alright
350 hydromatic and powerglide chatter001 Transmission - Rearend 1 08-09-2006 06:23 AM
350 turbo vs 2 speed powerglide dboyett38666 Transmission - Rearend 10 05-16-2006 07:31 PM
SBC 350 and Turbo 350 OR 2 spd Powerglide??? boneyard Buick Engine 5 04-04-2006 12:34 PM
NOVA: Powerglide or Turbo 350? chevy71nova Transmission - Rearend 1 10-13-2003 04:50 PM
powerglide to 350 speedo change? briwill Transmission - Rearend 1 11-12-2002 02:31 PM
