Check here.
If you are going to run it on the street, in my opinion the three speed trans would be a better choice. Drag race only, it's a toss up. The Powerglide can be modified to handle 600HP easily. Either must be matched to a properly sized and stall converter. The powerglide is a bit lighter than a THM 350. |
ok this is deff not going to see the street, the way this engine is build has been tailored towards the 1/4 mi putting a converter with a flash of 5500RPM behind it not trans brake as of yet the TH350 can take the 600HP if im correct or would a TH400 be the better way to go
If you are under 2700 lbs or so with you in it. Then a PG would work fine other than that a TH350 or a TH400 would be the ticket.
Either a TH350 or TH400 would do. Take less PF parts for a 400. But it is your choice. Takes more HP to run a TH400 but not much more. |
Excellent thanks |
powerglid
where are you from? if***************
*****************************s break on it also. Last edited by Crosley; 07-17-2011 at 03:30 PM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads. |
powerglide or 350
i would have to agree a 350 will hold up if you have it build rite i know acouple drag racers and they both had powerglides in and made two passes on one and the other made 8 pesses before it blew apart going 80 mph. i would say a 350 you get more gearing for off the line for a jump on the other car.
musclecarsrock68 ;
welcome to Hotrodders.com No sales , offers to sell or want ads in the main open forums are allowed. Use the classified section or contact the member via the PM system if you wish to offer to sell an item.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Powerglide or TH350? | lt1_performance | Transmission - Rearend | 8 | 05-03-2010 12:24 AM |
| powerglide or th350 behind a 383 | backyard71nova | Transmission - Rearend | 8 | 12-30-2006 12:02 PM |
| Powerglide or TH350??? | Dizturbed One | Transmission - Rearend | 7 | 06-06-2005 12:37 PM |
| th350 and powerglide | chrismac | Transmission - Rearend | 2 | 03-18-2003 02:22 PM |
| Going from powerglide to th350 | 67RS-Groundpounder- | Transmission - Rearend | 6 | 03-15-2003 04:34 AM |
