Powerglide or TH350??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2005, 05:49 PM
Dizturbed One's Avatar
Both are automatics, going into a 63 Bel Air Wagon.
The Powerglide is already in the car, and it would be nice to not deal with the driveline adjustments etc, but I heard that this transmission would be junk in this car since it's being used as a daily driver and will be seeing frequent freeway miles.
I heard this from a tranny guy, but I don't know how knowledgable he is since I've seen him do some pretty hairbrained stuff on his own car...
From what I understand the PG had no problems before, but it was getting pulled around by a beat to hell 327 (at least it had double humps, I'm swipin those for a cheap build later, lol)
I believe it has a pretty tall rearend also, with like 2.83 right now (hopefully talk the old man into putting at least some 3.23's back there, but I'm shootin for 4.10's, lol)
It's gonna be sitting behind a 350 bored .060 over with a XE268 cam, 1.6 magnum roller rockers, Edelbrock Performer intake, carb is undecided (probably a rebuilt Q-jet just to get it going), got a new flywheel for the tranny to hook up to also.
The tranny came with the motor but we have no idea if it's any good or not, so that's kind of a gamble. Not to mention messing around with the driveshaft and whatnot if we drop that in.
Any suggestions?
Please help, I'm clueless when it comes to trannys.
Old 05-14-2005, 08:02 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
nothing wrong w/either tranny other then the PG only has 2 gears. some folks love the PG's other hate them. the best part is the 350turbo is a direct bolt in (except for the shifter linkage down on the tranny) where the PG is now. which would I prefer???? i'll take 3 speeds anyday rather then 2.....joe
Old 05-15-2005, 03:05 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
You would get better performance with three gears, but there is nothing wrong with a Powerglide in that car, and it is "period correct". Our family had a few Chevys with Powerglides and they went down the freeway just fine.
Old 05-15-2005, 05:51 AM
rlackey's Avatar
Rich Lackey
Last journal entry: Rich Lackey is back on Hotrodders!
Any suggestions?
Can I make you an offer for your 327?
Rich
Old 05-15-2005, 12:53 PM
Rich
Sorry
Gonna build it up for my dad's 53 Chevy Pickup to the best of my understanding.
Thanks alot for your help though guys, I think I'll go with the TH350 since it's pretty close to being a bolt in. I'll figure something out for the linkage, shouldn't be too bad.
Old 06-04-2005, 11:19 PM
Either trans is good the glid or the th350 both will bolt in with no problems you will need to change the shifter tho. The drive shaft will bolt right up only thing will a glid is you need steep gears in the rear for when it is in high gear.
Old 06-05-2005, 12:07 AM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
Any suggestions?
Dizturbed I can help you with you dilema. I had a very similar set up in my 67 Impala conv. 327 .030 over, Comp Cams 268 hi energy cam, edelbrock performer, Q-jet carb and stk ex. manifolds. The car had a PG and a 3.08 gear. I swapped the PG for a Turbo 350 and never looked back. It is a direct bolt in and I even used my stock column shifter. While I was making the swap, I installed a TCI 11" converter. It felt like I added 50 hp and 75 lbs ft of torque to an already good running combination. It would spin the tires for 50 ft if you floored the throttle from a stop. I can't recommend this swap enough. You will love it.
P.S. If anyone needs a PG, I've got 3 on the shelf including one set up for a factory floor shift.
Old 06-06-2005, 01:37 PM
what do you need out of em?
Powerglide or TH350 transmission? sb72elcamino350 Engine 3 11-18-2004 06:56 PM
TH350 in place of powerglide? 87442lover Transmission - Rearend 4 04-24-2004 05:40 AM
Changing a powerglide to a TH350? Uber Transmission - Rearend 2 09-11-2003 12:43 AM
th350 and powerglide chrismac Transmission - Rearend 2 03-18-2003 03:22 PM
powerglide trans or th350 in 54 chevy? DeathByGreaser Transmission - Rearend 10 01-01-2003 09:52 AM
