street car, drag car, oval track car?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
If ya can't do an AOD, I'd try for a lockup 350. Easy 10% more mileage in my car just because of the lockup.
You want to use the automatic lockup feature and then install an arming switch so you can keep it off until you hit the highway. |
please don't think im stupid, i saw it in mags, i just really never paid attention to what it means.
GM has an electrically triggered clutch inside the torque converter to eliminate all slippage when it is engaged for highway cruising. It has a limited amount of torque it can hold.This is done automatically at about 45 mph in high gear cruise/ light throttle. There is an oil pressure switch that looks like an engine oil pressure sending unit inside the trans oil pan that controls this. It can be changed for different pressure settings to adjust the road speed of the engagement. In most cars it sounds like the 3 spd trans is shifting into a 4th gear when the slippage stops. It makes a solid 10% better mileage in my car. I suggest using an "arming switch" to prevent inadvertant engagement in performance useage. I have a Pontiac V8 with a 350C (lockup) trans in a G body. Since about 1980 most every auto trans in every brand car has some form of lockup. More than you wanted to know?
| Using powerglide Column Shifter with TH350? | Warrant | Transmission - Rearend | 1 | 05-15-2006 10:10 PM |
| Th350 Or 2 Spd Powerglide Chevy!!! | boneyard Buick | Transmission - Rearend | 2 | 04-04-2006 02:55 PM |
| Powerglide or TH350 transmission? | sb72elcamino350 | Engine | 3 | 11-18-2004 05:56 PM |
| TH350 in place of powerglide? | 87442lover | Transmission - Rearend | 4 | 04-24-2004 04:40 AM |
| th350 and powerglide | chrismac | Transmission - Rearend | 2 | 03-18-2003 02:22 PM |
