Powerglide trans to 400 Chevy motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2006, 10:54 AM
I have powerglide trans that came off my 327 motor. What will it take to bolt onto the 400 motor? The 400 has a different fly wheel than the 327. I know that the 400 fly wheel needs to be used. The stall converter does not appear to line up with the 400 fly wheel. Can I use a stall converter from a different Trans? I have a tranmission that came with the 400. It is not a powerglide. With that stall converter work on the powerglide? Thanks to any one that cane help.
Scott
Old 07-08-2006, 11:22 AM
re-tranny
I believe you have to have a stall to fit a power glide tranny
you can get them from auto zone
Old 07-09-2006, 07:25 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
You HAVE to use the 400 flywheel. You also have to use the converter for a powerglide. The converter can be from any manufacter that you chose, can also be any stall that you need or size. If the converter bolt pattern does not fit the flywheel. You will have to drill new holes, not a big deal. Most of the flywheels have both bolt patterns in them and the converter should just bolt up. I have used this combo in several race cars.
Old 07-09-2006, 08:43 AM
They also make a turbo input shaft for a glide so you can use a turbo converter, instead of a glide spline converter.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
454bbc with t 400 trans 19471/2ton chevy pick up timbro 42 Engine 8 03-11-2009 07:03 PM
350 Motor Mount Options for 53 Chevy JAHamilton Engine 4 08-20-2005 12:09 AM
817 block 400 chevy Chevy21 Engine 3 08-15-2005 02:26 PM
Chevy SM465 Man 4 SPD Trans? swoo55 Transmission - Rearend 0 10-26-2003 04:07 PM
