powerglide trans with no reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 06:31 PM
I have put a brand new powerglide transmission behind a 350 small block Chevy. I just got the engine running and found that reverse doesn't work. It will go forward, but I think only one gear is working. Anyone know what could possibly be wrong with my new powerglide?
Old 08-02-2011, 06:45 PM
clogged valve body? bad linkage?
Old 08-02-2011, 08:00 PM
Clogged valve body-linkage.
Thanks for the info. I have the shifter cable unhooked, and shift it by hand and there is no change. Is there a way to fix a clogged valve body with out removing the transmission?
Old 08-02-2011, 08:04 PM
i dont know if you have to remove the transmission or not, i'm running into the same problem with a th250.
Old 08-02-2011, 08:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I doubt you have a clogged valve body in a 'new' powerglide.
Please describe where the glide came from , who rebuilt it, is this a stock rebuild, do you know what year the trans is ?
Old 08-02-2011, 09:15 PM
Powerglide with no reverse
I ordered the powerglide from Abruzzi Transmissions in Ohio. I will talk to them tomorrow. It is a shorty and has a trans brake. It is their low dollar powerglide. I think I paid $1495.
Old 08-02-2011, 09:24 PM
no reverse
most brake glides have to have the solenoid engaged for reverse in reverse position its a safety thing built into the valve body(just in case your shifter goes past neutrel) not fun hitting reverse at 140mph happened to a friend ray cook hees lucky he walked away
Old 08-02-2011, 09:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes, call the builder.
If you have a budget bracket race glide , these often do not require the trans brake engaged for reverse. Put the shifter in "R" and the trans should back up
If the glide has a fluid release or a 'pro tree' style trans brake, then the t-brake button needs to be pushed in "N" or "R" for reverse to function.
Old 08-03-2011, 05:29 AM
powerglide with no reverse
Thanks--To All-- for all the information. In a couple of hours I will call the builder. I just hope I don't have to take it out and have something fixed. It is in a v8 trike I have built from a Boss Hoss frame and it is not easy to get the thing out. Thanks again.
Old 08-03-2011, 06:51 AM
Oh---Another question.Could you give me a quick lesson on how this trans brake should be wired. It has a solenoid and 2 wires--Thanks
PowerGlide Problems (no reverse) Dajerseyrat Transmission - Rearend 16 07-17-2011 08:10 PM
Powerglide. Drives in Reverse, but not forward calclown Transmission - Rearend 3 06-11-2010 06:37 PM
powerglide reverse problem dirtrackin Transmission - Rearend 2 03-21-2010 12:32 PM
PowerGlide Problems (no reverse) TailGater Transmission - Rearend 5 04-04-2006 12:16 PM
Which line is which on a powerglide trans? tm454 Transmission - Rearend 3 12-07-2004 07:21 PM
