powerglide transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2003, 01:04 PM
Lightbulb powerglide transmission
I have a transmission that came out of a 66 impala I was told it is a powerglide. I disagree because it has a aluminum housing it also has a electrical connector on it the numbers on the tailshaft are 3878427 and the number on the bell housimg is 115-2 if anyone can identify this trans through the numbers I would appreciate it.
Old 01-15-2003, 01:22 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
<= Double click on my Willys Avatar which will get you to my Photo Album. Open the tranny spotters guide I have posted there and you should be able to determine what you have.
Old 01-15-2003, 01:29 PM
Post
did the impala have a chevy engine? if not GM made a two speed for pontiac and olds called a 300, same as power gluid with electric kick down? bolt pattern different from chevy.
Old 01-16-2003, 01:42 PM
Post
is the electrical plug on the right (passenger) up by the cooling lines? If so it could be the first attempt at emission control,electrial solniod sending vacumn to the dist in high gear only, if so remove switch (with oil preasure sending unit socket) plug hole with 1/8 in pipe plug. If the switch is on the other side you eather have a 300 or a 400, only tranie that old with elctrial plug. good luck.
Old 01-16-2003, 02:15 PM
Post
by the weay 66 caprice 396 came with th400, mabey someone changed it?
