Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - powerglide withe turbo shaft need a converter with stator bushing built in
Old 02-27-2012, 07:14 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by pleaseu540
I have a powerglide with no stator bushing. i cant find torque converter number with bushing installed unless i go with 3500 stall. i want about a 2000 stall. can anyone help me? Jegs and summitt cant tell me what i need.
I am guessing your stator tube end on the glide is not machined for a bushing?
Call Hughes Performance, talk only to Pete. He will advise you on this since what you are looking for is not common on a low stall converter with the internal bushing on the turbine hub.
