-   -   powerglide withe turbo shaft need a converter with stator bushing built in (http://www.hotrodders.com/forum/powerglide-withe-turbo-shaft-need-converter-stator-bushing-built-215567.html)
pleaseu540 02-27-2012 07:06 PM
I have a powerglide with no stator bushing. i cant find torque converter number with bushing installed unless i go with 3500 stall. i want about a 2000 stall. can anyone help me? Jegs and summitt cant tell me what i need.
Crosley 02-27-2012 07:14 PM
I am guessing your stator tube end on the glide is not machined for a bushing?
Call Hughes Performance, talk only to Pete. He will advise you on this since what you are looking for is not common on a low stall converter with the internal bushing on the turbine hub.
pleaseu540 02-27-2012 07:26 PM
Thanks for ur help!!!!
