powerglide withe turbo shaft need a converter with stator bushing built in - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2012, 07:06 PM
I have a powerglide with no stator bushing. i cant find torque converter number with bushing installed unless i go with 3500 stall. i want about a 2000 stall. can anyone help me? Jegs and summitt cant tell me what i need.
Old 02-27-2012, 07:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am guessing your stator tube end on the glide is not machined for a bushing?
Call Hughes Performance, talk only to Pete. He will advise you on this since what you are looking for is not common on a low stall converter with the internal bushing on the turbine hub.
Old 02-27-2012, 07:26 PM
Thanks for ur help!!!!
TH 400 Tail shaft Bushing ID Size dbilski Transmission - Rearend 1 08-24-2010 07:38 PM
Stator Shaft Help Brkingspider Transmission - Rearend 2 03-23-2009 04:14 AM
C6 tail shaft bushing removal cboy Transmission - Rearend 11 08-07-2005 05:46 PM
T-400 Input Shaft Bushing 68NovaSS Transmission - Rearend 0 12-30-2003 06:03 PM
AOD REAR OUTPUT shaft, buSHING buckhorn Transmission - Rearend 5 10-26-2003 10:00 PM
