Powerglide Won't Shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 06:43 PM
I have 66 c10 with a powerglide. Cruising at 50mph for about 10 miles, it will downshift to first. So I slow to 30mph, and it stays in first for about a mile. Then I loose everything, no drive, no reverse, nothing. I let it sit for ten minutes, then its fine again, for about 5 miles, then it repeats. I also noticed that when I shut the truck off and try to restart, it acts like a weak battery or timing being off. I've checked fluid(clean and full), timing, disconnected detent, engine temp is normal. This tranny was supposed to have been rebuilt, but i'm not 100% sure. Any help would be appreciated.
Old 05-23-2005, 08:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sounds like a filter clogging up.
There was an aftermarket dacron style filter for the glides. these filters can clog up , stop the car.
As the fluid drains back out the tranny through the filter while the egine is off, Start the engine & the car will move again for a mile or 3 , then drop out of gear again....
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
Aluminum Powerglide shift lever. shaggy56 Transmission - Rearend 1 10-10-2003 12:02 AM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 05:52 PM
