Powerglyde or T-400 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2013, 07:00 PM
wich would be better for drag racing .all that im hearing is personal prefrence.wich one will give me a better launch with a 4000 stall an trans brake
Old 07-06-2013, 07:02 PM
BOBCRMAN@aol.com's Avatar
Not that simple.. What do you have? Engine size/hp. Body style. Weight, Tire size etc.
Old 07-06-2013, 07:11 PM
68 nova 383 stroker about 475 hp (never had it on a dyno) 15/10/29 tire.not sure of the weight but everything that can be gutted is taken out.running a 4:56 rearend
Old 07-06-2013, 07:38 PM
Powerglide but would work better with 4.88 gear
T400 if you keep 4.56 and get more rear tire I realize these bodies are somewhat tire restricted with stock body. Back in the day I ran a 70 with BB in it. 10.9 tire was the most tire that would fit. Lots of traction issues.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
haulingas (07-07-2013)
Old 07-06-2013, 08:02 PM
an pretty much the only way im goin to be able to get more tire back there is to go with a 4 link frame kit huh?
Old 07-06-2013, 11:52 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ah yes that will be needed..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 07-07-2013, 02:13 PM
So what is all envloved in putting that on?
Old 07-07-2013, 04:06 PM
4 link cost
Sub frame connectors, 6 pt roll bar rear frame rails 4 link kit narrowed rear end housing Axles ,spool rear gear, coil over shock kit rear brake kit to fit rear wheels/tires to fit narrowed rear end, wheels tubs and interior kit. This could cost 6-10K
Old 07-07-2013, 07:15 PM
A lot simpler to run a Glide and a bit more gear.
Old 07-07-2013, 10:06 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
No body has said this yet and should have.Unless your deep into tooling and equip where your making your own frame rails/kit,the chances of you building a 4 link car cheaper than buying a 4 link roller are not very good.The question of a glide certainly directly involves the car's wt,final gear ratio,power band of the engine,rpm limits.BTW the wt includes the fact a 350/400's wt is heavier than a glide.The reciprocating wt of a glide is less than a 350/400's wt as well.It's because of that fact a glide is more of a reaction trans.But 40 yr old glide cases are not built to hold up against today's engine outputs.Because of that a aftermarket case is almost a given.I'm telling you that founded on 30 yrs or so of glide use in many different cars in Super Gas with a brake. And they aren't cheap.
The Following User Says Thank You to 1Gary For This Useful Post:
haulingas (07-09-2013)
Old 07-08-2013, 06:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
At ~475 HP, I'd be looking at a TH350. Not that much heavier and closer gear splits to keep the engine in the powerband better than a PG. Allows a little less rear gear ratio. If you were to drive this on the street that can be a plus.
You could set up the rear end w/a 4-link and mini tub it. This will give you plenty of footprint for that power level.
To get an idea of what it takes to install a ready made kit, take a look here.
More general rearend info here.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 07-08-2013, 07:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The 68 Nova dont need 4 link and tubs at that HP level.
There are similar cars that run in the NMCA type races with stock suspension with Cal-Trac bars on drag radials that run into the 8 second zone in the 1/4 mile.
On radials the T-350 may work well with the low HP
Torque converter design would be very important
The Following User Says Thank You to Crosley For This Useful Post:
Old 07-08-2013, 07:56 AM
vinniekq2's Avatar
Im in the 3 speed crowd,especially with your lower HP and only 4.56 gears.When I put a glide in my 67 Camaro I also put 5.57 gears,with a similar low output engine and I used a 5,000 plus stall
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 07-09-2013, 06:00 AM
So I guss I will get a turbo 350.I have a t 400 maybe I can find someone to trade.or somthing.thanks for your help you guys kick ***
Old 07-09-2013, 07:06 AM
vinniekq2's Avatar
use the turbo 400.Its a little longer.move the cross member back,shorten and balance the drive shaft change the yoke
400 sbc. . T-400 or 700r4 blackpanther68 Transmission - Rearend 2 08-05-2012 06:32 AM
1967 400 with 670 heads. Trying for 400 Hp street 67pontiac400 Engine 23 07-20-2012 08:45 AM
Bolt pattern from a chevy T-400 to cadillac T-400 nthogdog Transmission - Rearend 7 03-23-2011 07:05 PM
400 pontiac and 400 chevy?are they the same? 77'Omega Engine 34 07-01-2010 01:10 PM
Olds 455 or pontiac 400/400 handymann3 Engine 48 02-03-2010 04:59 PM
