Powermaster Alternator Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2008, 11:57 AM
mrdreex's Avatar
Ok, fairly new to alternator wiring, but I think I have the general idea. I jsut want to check with someone who may know before I actually do it. I have a Powermaster 140-amp alternator that is a three wire. My alternator is a 3-wire, but I am unsure of how to exactly wire it to my application. I purchased a Painless harness to go along with it (harness as in the one that plugs into the pins in the back of the alternator) and it has two wires coming out of it, and which two terminals they come out of exactly is a bit fuzzy at the moment. The terminals are labeled respectively on both harness/alternator P L F S.
I know I have to send the charge wire from the alternator to the back of the starter lug, but am kind of fuzzy on where I connect the other wires to. There's a red wire, and then there's a white wire, which (in the directions) needs a resistor in between it and wherever it connects to. Is this the voltage sensing wire?? Does this hookup to the ignition switch that I have inside on a switch box?
Here is a link to the harness I am using:
http://store.summitracing.com/partde...part=PRF-30707
http://static.summitracing.com/globa.../prf-30707.pdf
Thanks!!
Old 12-31-2008, 12:42 PM
T-bucket23's Avatar
Wiki Edits: 26
The #1 terminal goes to the dash light or another hot when on source, if you dont use a light it needs a resistor in the line. The #2 wire is the voltage sensing wire. It should go a 12 volt connection near the fuse panel some where to make the alt work efficiently.
There are several threads here on this subject and if you google 10si wiring you will get tons of information. The Mad electrical site probably has the most complete information on this subject you will find anywhere.
Most harnesses are already setup up for a 10si alternator, Im surprised yours is not
Chet
Old 12-31-2008, 12:48 PM
mrdreex's Avatar
I have googled as well as read the entire Mad electrical article. It never once says where it connects to - only references the junction block. Does the wire connect to a specific wire ONLY for this purpose? If this is the case, my car may be too old to have a wire for that, as it's a '70 Nova and it didn't come with an internally regulated alternator. The voltage sensing wire is I'm guessing the mystery red wire, and is that a positive lead from anywhere throughout the car (junction point/lug at the starter??) that goes to the alternator to regulate the voltage throughout? If that is the case, can I have both the battery/voltage sensing wire spliced together to the back of the starter? Or would that basicly be turning it into a 'one-wire' and not 'sense' the correct voltage for compensation throughout the system?What is the purpose of the white (wire that needs a resistor/ignition switch) wire? Does the alternator need to be turned on to work? It's just a bit confusing when I've never had to wire this from scratch before.
Please don't mistake lack of knowledge as lack of research. I've built an entire engine from ground up myself over the past year, and am about to start it up this weekend. (incredibly excited!)
Thanks T-bucket23!
Old 12-31-2008, 02:02 PM
302 Z28's Avatar
Keep the charge wire as short as possible and use at least a #10AWG wire. It can connect directly to the positive battery terminal or a junction point to the positive battery terminal. That year GM product usually used the horn relay as a junction point. See the attached .pdf file.
Vince
Old 12-31-2008, 02:09 PM
T-bucket23's Avatar
Wiki Edits: 26
I will try to dig around to see if I have the specs for the resistor.
Thanks T-bucket23!
Connecting the sense wire to the same place as the large charge/feed wire will work but it is not the best way to do it. Connecting it somewhere close to the fuse block would probably be better. If you have an unused fues you could use that.
I dont recall what the resistance needs to be for the wire that excites the alt (pin 1) but I know it was covered here. If you are using a light then it is no big deal, if not the voltage should be dropped a little.
Chet
Old 12-31-2008, 02:10 PM
mrdreex's Avatar
Nevermind, you cleared it up for me T-bucket23. Thanks again guys!
Old 12-31-2008, 02:13 PM
T-bucket23's Avatar
Wiki Edits: 26
Read this thread, post 6 has a lot of information that may apply to you. Also there are a couple of simple diagrams for converting from a external regulator to an internal. They may not apply directly but good basic info
Alternator thread
Chet
400 staggered bolt mini starter...Powermaster 9612 ??? ddhens Engine 3 09-07-2008 04:39 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 03:46 PM
Powermaster 140A Overcharging 68NovaSS Electrical 8 10-08-2007 10:53 PM
New Powermaster alternator, broken? arch Electrical 2 06-12-2004 11:38 PM
specs on a powermaster 350? slammedchevy86 Engine 1 03-23-2003 07:51 PM
