Powersteering pump noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2008, 06:26 AM
I have a 1984 Dodge 1 Ton 318 motor .When i turn the steering wheel to the left or right it makes a lot of noise. It is full of fluid i hate to go buy a new one even for that old truck it around 80.00 if it sits for awhile it does leek a little as it is not a daily driver . And you don;t have to turn it that far to left or right for it to make a lot of noise. thanks for any help.
Old 01-18-2008, 10:07 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
A loud whining coming from the P S pump is
usually a sign of a pump going bad, there are
a couple of things you can try, first (easiest) a
couple of ounces of Sea Foam, next, bleed the sys.
next, change the PS pump, when you change the pump
be sure to flush all the old fluid out as it could have
metal in it,
Good luck,
Rich
Converting to EFI 65fish Engine 12 11-10-2007 07:17 AM
87 Suburban fuel pump help needed Mustangsaly Engine 14 10-29-2007 09:04 AM
fuel pump noise? oldguy829 Engine 2 08-07-2006 02:49 PM
Help track down a weird noise curtis73 General Rodding Tech 10 05-01-2006 11:38 PM
holley accelerator pump 87 350monteSS Engine 8 07-18-2003 06:51 PM
