Powersteering pump problems. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2011, 02:52 AM
Maybe not the right place for this thread but I will try my luck anyway. I have a powersteering setup consisting of a toyota hiace rack and a very compact mitsubishi pump. For the last couple of years it has worked beautifully, but now all of a sudden it is playing up. My steering feels like it is locking up from time to time and it only seems to be when I apply any lock just off the straight position. It is very heavy for a moment then all of a sudden will free up. It also seems to be worse turning right than it is turning left. The first thing I did was check fluid levels of course and there appears to be plenty of fluid. Any ideas?
Old 10-18-2011, 03:05 AM
DoubleVision's Avatar
Mostly when this happens it`s time for a rack replacement.
Old 10-18-2011, 03:10 AM
Rack is second hand but has had all new seals fitted. The problem started suddenly, not gradually. Is that normal for a worn rack?
Old 10-18-2011, 11:27 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moving this to the suspension/steering forum, better exposure.
Semper Fi
Old 10-18-2011, 11:53 AM
Ok thanks for that.
Old 10-20-2011, 05:03 PM
Well guys i topped up the fluid level even tho it appeared to have plenty in it and took car for a drive, no change. I took car to a friends and took a friend of his for a drive. Gave the car a bit of a good thrashing and steering fixed itself. Fantastic! Must've had an air lock or something in the system. Gota love problems that fix themselves
Old 11-01-2011, 02:14 AM
Buga, problem came back. Time to start pulling things apart I guess. My guess is a bit of crap stuck in valve body somewhere, only hope it's that simple!
Powersteering Pump SBC vs BBC 454headache Hotrodding Basics 4 07-10-2010 02:38 AM
sbc powersteering pump bracket for headers nicksowinski Engine 2 02-16-2010 07:34 PM
Powersteering pump noise dcpky Electrical 1 01-18-2008 10:07 AM
powersteering pump wont work spankthru Engine 0 06-14-2003 10:40 AM
additive lowers temp in radiator,trans. and powersteering pump IHAVECHEVYPARTS Engine 4 11-21-2002 07:42 PM
