Powertrax locker - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2005, 10:13 AM
Powertrax locker
My GTO has been sitting for 4 years while I have been restoring it. It has a powertrax locker in it and now when you take sharp turns or take a turn with it in gear the whole car starts to buck. I believe that the powertrax is locked up. I replaced the fluid and put GM posi lube in it. Has anyone else had this problem or does anyone know of a good way to unlock it other than to just drive it and hope that it unlocks? Thank you.
Old 06-07-2005, 11:56 AM
dawg's Avatar
NAVY VETERAN
ii know somone with same problem.
car sat for about 4to 5 years andrear end acts like a spool.
he got powertrax too.
he removed the cover to discover moisture in it differential. (condensation)
the powertrax was slightly rusted.
he said he got it working again by working the components with a screwdriver.
Old 06-08-2005, 06:17 PM
broncoII88's Avatar
Do the right thing...
All locked up!
Well with the powertrax or any locker for that matter, understeer occurs when turning because the locker is trying to turn both wheels at the same speed, which makes a squeak, but it shouldn't be bucking. What they said. Take it out and get it moving!
Installing powertrax trouble 66novaht Transmission - Rearend 1 02-26-2005 01:24 AM
installing powertrax camino_man Transmission - Rearend 6 12-18-2004 05:33 PM
Powertrax info needed YC69Camaro Transmission - Rearend 4 11-28-2004 11:57 AM
Powertrax Locker: 1/4 mile time increase? purple1967camaro Transmission - Rearend 3 04-12-2004 07:23 PM
Whats a locker (not in the airport) scott ticknor Transmission - Rearend 2 07-26-2003 09:52 AM
