-   -   PPG Concept single stage with a color sand, how many coats to shoot? (http://www.hotrodders.com/forum/ppg-concept-single-stage-color-sand-how-many-coats-shoot-209848.html)
psychoholica 12-05-2011 02:31 PM
So we're about to shoot my 1966 VW bus with PPG Concept this weekend! Im using original colors, Sea Blue and Cloud White, single stage with a color sand to finish it off. Just wondering if anyone has a recommendation on number of coats to shoot. The spec sheet says two but thats for base/clear im guessing, we're debating between 4 and 5.
I bought a Devilbiss Tekna with a 1.2 for the job.
Very excited, after years of cutting, welding, fillering, sanding and finally sealed with K38 and wet sanded with 600 its finally ready to paint!!
here are some pics, http://66split.com
How many coats?
shine 12-05-2011 02:54 PM
i use concept for color. i will usually shoot 3-4 coats then block and do 2 nice coats. cuts down on the thanewave and such. depending on color i sometimes clear it.
Metroman 12-05-2011 03:52 PM
I have found that the PPG Concept whites dry very hard. Sanding the fine scratches out took forever. The last car I painted with white, I cleared it. It was a much easier job to buff out. I didn't have any problem with red or blue. I hope this helps.
psychoholica 12-05-2011 04:44 PM
Im trying to get the bus back to as original as possible so staying away from clear for sure. Never thought of 2 then a block.
Interesting on the white drying hard. How long after you shoot do you do a wet sand and buff?
Metroman 12-05-2011 05:05 PM
I think I waited about a week. Yes, it is interesting that colors sand different than white. After finding this out, I also heard it from another person who painted white. If you can spray it with the least amount of orange peel, it would probably look the way it was painted back then. Concept does lay down nice. :thumbup:
shine 12-05-2011 05:38 PM
if your going to buff concept you best get on it within 48 hours.
i block after overnight dry then recoat. give it 24-48 hours and get it buffed.
mitmaks 12-05-2011 06:32 PM
What he said, don't wait too long. Same goes with many clears also. Wait too long and then it will be PITA to buff it out
Metroman 12-05-2011 06:45 PM
What is your reason for double painting.............curious?
Seems like extra work.
psychoholica 12-05-2011 07:34 PM
Wow, very glad I asked! I was planning a few weeks! Im thinking maybe only block the blue on the bottom half of the bus and leaving the white untouched. I'll make the call when how smooth it lays down. Curious on why two as well.
shine 12-05-2011 08:03 PM
each coat you apply will add trash and peel. once covered it is blocked smooth then recoated. only 2 coat of trash or peel to seal with.
Metroman 12-05-2011 09:36 PM
I've never heard of such a thing. :nono: :nono: :nono:
What kind of trash are you picking up??...............and peel?
shine 12-06-2011 05:19 AM
in a 100k dollar down draft none but someone painting in a garage will get air borne trash in it. peel depends on your gun control .
skyraker 12-06-2011 07:50 AM
home painting by hand
This may seem a crude thing to discuss with experienced painters, but recently I saw an article by a fellow that painted an older model Ford Ranger by hand. He mostly used a roller and he primed and painted with Rustoleum paint right off the shelf. He did do a lot of blocking and buffing, but the result he got was very good. Just curious if anyone else had heard of doing it this way. Skyraker
shine 12-06-2011 08:25 AM
it's called "tipping " . painting by brush. but i would never use rustoleum when there are quality urethane's to brush on. most marine paints are well suited for it.
psychoholica 12-06-2011 11:16 AM
lol I just couldnt imagine dunking a rolller in $3500 of sexy PPG Concept!!
Thanks for the advise guys, we shoot paint in 4 days!!! cant wait.
