ppg dcc 9300 final sand grit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 11:04 AM
product sheet says 400-600
I sprayed dp epoxy then 4 coats of k38
then blocked with 80 and 180
then spayed 3 more coats and blocked with 180
sprayed 4 more coats on Saturday (a whole gallon)
and think I am going to block once more with 320
is 320 enough or should I hand sand the 320 scratches with 600 after the final blocking.
I am going to spray a coat od dp as a sealer before the dcc.
Thanks for any help
p.s. this is a LOT of work
Old 07-14-2008, 11:05 AM
and......
do I need to wet sand or will dry be fine
Old 07-14-2008, 12:14 PM
One more thing....
Aftrer all my blocking I really dont want to screw it up by hand sanding.
is using a stiff pad good enough to keep my blocking straight?
Old 07-15-2008, 05:34 AM
I think you're shooting a singlestage urethane dcc9300? Is this Concept black if I remember correctly? If you're shooting a coat of DP as a sealer then 320 dry should be fine enough, a good rubdown after the sanding with a grey scotchbrite will also help. If you're after perfection you may also want to shoot three coats of color then block it with 600 wet and shoot a couple more flow coats.
Old 07-15-2008, 11:17 AM
Yes concept black single stage urethane.
I started blocking with 320 last night and still broke through to metal in 2 places so far, but just barely.
Bare metal spots are small (like smaller than a quarter).
Can I just spray the sealer (reduced dp) over these tiny break throughs? Or am I going to need to spray high fill and block again?
I wet sanded to 600 also.
I was unsure of 600 and dp holding?
If Dp will grip 600 then I would rather not risk sand scratches ruining my hours upon hours of blocking.
Thanks
Old 07-15-2008, 11:23 AM
Yes, the dp will adhere fine to surfacer sanded at 600. And for quarter sized and smaller sandthroughs I would definately just seal with DP and go to paint.
Suggestions on a paint system other than PPG camaro freak Body - Exterior 10 04-03-2007 05:32 PM
toughest paint acsteve Body - Exterior 29 12-25-2005 01:07 PM
PPG Expert needed.... Beenaway2long Body - Exterior 1 03-25-2005 10:01 AM
