PPG Deltron 2000 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2013, 05:45 PM
PPG Deltron 2000
Just painted my 1961 Corvette on which I am doing a rotisserie restoration. Two weeks ago I had a professional painter shoot the basecoat (PPG 2000) and clear coat (PPG DCU 2002.
Since then I have discovered a couple of prep flaws (I did the prep using PPG's All-U-Need and K-36).
My question is: Can I refinish just the immediate areas of the flaws, or do I need to redo the entire panels which contain the flaws? Either way, what is the process? Filling and priming with K-36? or what???
Sure wish I had noticed the flaws before painting.
Any help would be appreciated. Except for these two flaws, it looks perfect!
Old 04-30-2013, 08:07 PM
I assume it must be a flaw that must be too much to wetsand & polish? If the flaw is that bad why would it have been painted over? Would have been easier to repair before it was finished. It would be best to repair, then blend your color & clear the entire panel. Pictures or better description of the flaw would be helpful, dirt or sand scratch etc.
Old 05-01-2013, 08:14 AM
'61 Corvette Paint Flaw
You are so right! I should have caught the flaws prior to taking the car to the painter. I have learned the hard way to be more thorough in my inspection of the paint prep.
Thank you for your advice.
Old 05-01-2013, 08:28 AM
Faith - Respect - Trust
X2 on what ppgsprayer said, for next time, prep flaws can often be caught if you use guide coat...when used properly, the smallest pin hole, sand scratch whatever can be detected before you apply that expensive top coat.
And yes, pictures or a better description of the flaw would enable a better response on how to repair the flawed areas.
Ray
Old 05-01-2013, 12:39 PM
I would see what your painter thinks should be done. experience counts for alot in the giant chemistry experiment that is painting.
Old 05-01-2013, 08:48 PM
302 Z28's Avatar
It depends on what color it is as to how easy it will be to repair and spot. Have to ask why anyone with a 61 Vette would not go over it with a fine toothed comb before sending it to a painter. Also what painter would see obvious flaws and not advise the owner?
Vince
Old 05-01-2013, 09:18 PM
Vince
X2 on the painter Vince...he's the last line of defense...when I painted in shops...I was in charge of the preppers...the reason, I was supposed to know what would be acceptable and what what wouldn't...that responsibility lays heavily on the painter....after all, I was a prepper before I ever painted the inside of a fender.
Ray
PPG Deltron Epoxy Primer trackdown Body - Exterior 21 01-26-2013 08:48 AM
PPG Deltron Question SoCal66 Body - Exterior 10 01-13-2012 07:47 AM
PPG Deltron alternatives mitmaks Body - Exterior 14 11-22-2010 07:49 PM
Anyone have trouble touching up PPG Deltron paint? HardcoreZ28 Body - Exterior 2 03-02-2009 08:58 AM
PPG Omni Vs PPG Deltron camaro freak Body - Exterior 6 04-14-2006 11:51 AM
