Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - PPG Deltron Epoxy Primer
Old 01-22-2013, 10:20 AM
John long John long is offline
Originally Posted by Dayo5 View Post
Hi,
I am having some sim. issues. Are you guys recommending: full sand/ repair, then epoxy primer, Then filler on top of the primer, then Base? I am trying to get my order of operations set. Thanks!!
The Epoxy is designed to go over bare metal before any filler work is done. The beauty of that is it will protect the bare metal from moisture. For heavy filling you will want to use the normal body filler and/or 2k high build primer surfacer and finally sealing with Epoxy before paint.
What some of us have done on minor issues that do not require filler or heavy build is to apply extra coats of SPI epoxy to attain moderate build. Then all that is required is blocking and painting. From what I understand, the build qualities of SPi epoxy are about 1/2 that of a 2k primer surfacer.
