So the rest of the door didnt have any adheasion issues,it was just at the body line??? |
So far, I am finding places in this groove I can peal the epoxy of with my pocket knife and areas that are adhered well. Even though I have no failures outside the groove I need to feather it down and check it. I will post pictures and description of what I find. John L |
Well, here we go. I have one door blocked ready for Epoxy. It appears to me the issue is only in the body reveal line. You can see that the DPLF feathered well once I got back from the reveal. It also has adhesion and can not be scraped easily with a razor blade. I found:
Very shiney metal in the groove Lots of material build up. Unable to determine if any acid residue. I have scuffed the bare metal well with 180 grit dry and will clean it well with W & G remover letting it dry well before I prime with 2 wet coats of SPI black epoxy. I am going to post a couple of pictures that I hope show what I have done. ![]() ![]()
John, this raises a good point, I always say,if you use ospho or phosphric acid always sand it well before you prime.when I sand I always sand the field first and the edges and body lines last by hand sometimes I forget a body line so I always sand all the lines at the same time so I dont miss any and all the edges at the same time for the same reason ..It looks to me like you may have simply missed hand sanding the lines ,its an easy enough thing to do since the cant tell just by looking at it like you can with a primer and thats why SPI says they dont "recomend" using acid products ,it's so easy to miss something even for a pro but theres so many ways a newbie can screw up using acid its just easier to completly eliminate them from the equation...Sure the job wont last a long without uing acid but it'll look good for as long as it does and without any issues
| PPG Epoxy Primer | daveh | Body - Exterior | 6 | 05-08-2012 09:31 AM |
| PPG Epoxy Primer | 1putt | Body - Exterior | 19 | 03-03-2012 03:21 PM |
| Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? | off2wildblue | Body - Exterior | 2 | 07-29-2010 08:53 PM |
| PPG epoxy primer | mustangguy | Body - Exterior | 2 | 05-18-2003 04:25 PM |
| PPG epoxy primer probs. | Gearhead forever | Body - Exterior | 12 | 01-14-2003 08:26 AM |
