-   -   PPG DP90 Vs. Dupont ?? (http://www.hotrodders.com/forum/ppg-dp90-vs-dupont-113318.html)
solidaxel 04-07-2007 07:56 PM
I have a sandblasted truck cab and I want to cover it in a black metal etching sealer primer what does Dupont have that is that same as PPG DP90?
This cab will be outside and will not have a color coat for a long time what should I use in Dupont?
bullheimer 04-07-2007 10:06 PM
if there is such a thing as any primer that is both an etching primer and a sealing primer, i would like to know about it. as far as i know there aint. but ah is a po dum white boy
302 Z28 04-08-2007 06:43 AM
The best thing you can do is lay on a layer of Southern Polyurethane's etching epoxy primer. The best cost effective protection you can get IMO. It outperforms anything PPG or DuPont has.
Vince
bullheimer 04-13-2007 12:31 PM
thanks 302. you can use a high build sandable primer over it can't you?
baddbob 04-13-2007 09:27 PM
I second the SPI epoxy advice, and yes you can spray any primer surfacer over it or any topcoat and the epoxy itself is also very sandable after full cure is reached. High zinc phosphate content. Very good stuff.
For a sandblasted surface there's absolutely no need for a 1K self etching primer, in fact some self etch primers shouldn't be sprayed over a sandblasted surface.
solidaxel 04-14-2007 12:24 PM
Thanks You very much for the replys.
