PPG DP90 Vs. Dupont ??
I have a sandblasted truck cab and I want to cover it in a black metal etching sealer primer what does Dupont have that is that same as PPG DP90?
This cab will be outside and will not have a color coat for a long time what should I use in Dupont? |
if there is such a thing as any primer that is both an etching primer and a sealing primer, i would like to know about it. as far as i know there aint. but ah is a po dum white boy
The best thing you can do is lay on a layer of Southern Polyurethane's etching epoxy primer. The best cost effective protection you can get IMO. It outperforms anything PPG or DuPont has.
Vince Last edited by 302/Z28; 04-08-2007 at 06:54 AM. |
thanks 302. you can use a high build sandable primer over it can't you?
Thanks You very much for the replys.
| ppg deltron or dupont centari 600/6000s? | 73rustbucket | Body - Exterior | 5 | 11-05-2006 01:49 PM |
| PPG D800 vs Dupont Chroma | delanda | Body - Exterior | 0 | 07-19-2005 03:00 PM |
| PPG Omni or DuPont Nason for first paint job? | flipp121 | Body - Exterior | 35 | 07-14-2005 10:47 PM |
| Dupont vs. PPG | nd500 | Body - Exterior | 3 | 05-20-2003 08:58 AM |
| Is PPG the same as DuPont and I don't know it? | Coodeville | Body - Exterior | 3 | 06-20-2002 12:34 PM |
