Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - PPG Epoxy Primer
Old 02-25-2012, 08:21 AM
Old Fool's Avatar
Old Fool Old Fool is offline
Originally Posted by 1putt
Hmmm may need to look into that one instead. The PPG DP50LF was $90/qt with the cat-thought that was a little high.
Originally Posted by 67Elcamino
I do notice a huge Gap in Epoxy primers.. from close to $100 a quart to $40 a quart.
Is cheap Epoxy better than no Epoxy? If SPI is as good as they say that is a killer deal and wish I would of started that route when I began my project.
I believe there was a previous post where someone stated that once cured you can swipe with Laquer thinner to test the quality?
SPI is THE epoxy as far as I am concerned. As with any product use it properly, follow the manufacturers recommendations.
SPI ships FREE to your doorstep if you do not have a local distributor.
A little mentioned product is their urethane reducers. They are made from virgin ingrediants and are superior to any other reducers I have used. The cost is far easier on my wallet too.
Check out their pricing @ http://www.southernpolyurethanes.com/Pricing%20Info.htm.. And remember always compare pricing of paints as sprayable quanities as the mixing differences make it hard to compare otherwise.
