-   -   PPG Epoxy Primer (http://www.hotrodders.com/forum/ppg-epoxy-primer-219117.html)
daveh 05-07-2012 06:51 PM
PPG Epoxy Primer
Hi guys,
I have some unopened PPG epoxy primer that's about 10 years old and always kept in the house not the garage. Will it still be good? Just wondering it seems ok the cans aren't bulging or anything. Thanks
rdupree 05-07-2012 08:48 PM
Probably still good, but the solids may be VERY solid in the bottom. The bigger problem will be finding catalyst. You probably have a DP** product, which was replaced by DP**LF products. The catalysts are not compatible.
daveh 05-07-2012 08:58 PM
I do have the catalyst that I bought with it as well. And like I said it has been kept dry in the house.
marks custom paint 05-07-2012 09:34 PM
mix some up and spray alittle onto something if it is "seedy" or grainy it isn't any good I just used some that was at least 10 yrs old on my boss's 1969 boss 429 and it was fine
deadbodyman 05-08-2012 06:23 AM
Unless its DP-40 I wouldnt waste my time with it ...Thats the only PPG epoxy that was any good in the first place. Now days theres some fantastic epoxy primers out there and much cheaper than poor preforming PPG
If its just a spot or a fender,a lawn mower etc... I might use it but not on a whole car that I care about.
daveh 05-08-2012 08:30 AM
It's DP402
JohnnyK81 05-08-2012 10:31 AM
I like the DP epoxies.. Might as well try it out, you already have it!
