PPG K36 primer w/ purple gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2006, 12:59 PM
BIGSKY's Avatar
See project in Photo Album
I am laying down K36 with my new HF purple gun and I have a question about how it is supposed to spray and lay out. This is my first experience with painting, and in preparation I have spent lots of time here reading old threads, and taking advice from my paint guy, who has been very helpful.
I am restoring a 71 Chevy pickup at home in my garage, currently working on the bare cab. Its heated and 65-70 degrees is maintained around the clock. I have applied three coats of K36 over PPG epoxy primer. The epoxy I scratched with scottbrite and 100 grip. After three coats of K36 I blocked with 220 all over and 400 on the dash and pillars. My first concern is that I am not moving enough material through my gun. To apply a nice wet coat of primer I have to hold the gun 8 inches from the surface and go quite slow, and that's not how it looks like they do it on TV! My fan pattern seems the correct shape btw when I test on my vertical cardboard test box.
Another concern is that my 4th coat of primer is not laying flat everywhere on top of my seemingly smooth blocked primer surface. On the vertical surfaces like the dash, pillars, and rear of the cab it came out fairly good, but on the roof and door sills I seem to have what looks like lots of little bubbles when the primer is first laid down. After 15-20 minutes those are nearly gone, but I can still see some evidence of the "bubbles" after drying. I am mixing the K36 and K201 catalyst per the can and tech sheet at 5:1. For the 3rd and 4th coats I also added approximately a 1/2 part of acetone. Compressor is puting out 130, gun regulater is set at 40, and I am using the 1.4 tip. I have been diligent about using surface cleaner DX330, wiping that dry and allowing some dry time after that, then tack ragging before spraying.
Obviously however the primer comes out I can block it to be ready for color, I just want to make sure I am applying my primer correctly. I will be spraying Concept SS red over this primer and am hoping I can get a nicer finish when I get to shooting color.
So am I expecting too much from the infamous purple gun and/or am I being way too picky about my primer?
Old 11-14-2006, 01:21 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
Do you have the correct "purple" gun? HF sells several paint guns in the same color and not all are HVLP. If yours has HVLP on it then you are okay ...to a point. That gun has a 1.4 tip which is good for base and clear but not the best option for high build primers like the K36. A 1.8 tip would be better but I do not think such a tip is available for the HF HVLP cheapie gun. I used my HF gun to throw my primer on and it was acceptable at a 4:1 ratio but I upgraded to a Devilbiss Finishline set witha 1.8 primer gun and am able to throw more primer than before. You will experience some tip clogging on the 1.4 tip also.
HF does sell a purple gun with looks very similar to the HVLP model but is not HVLP. I have one I use for latex and oil base paints.
Old 11-14-2006, 02:20 PM
Don't use acetone, Mix your primer 5-1-2 (5parts primer, 1part activator, and two parts urethane reducer DT)
Old 11-14-2006, 05:23 PM
BIGSKY's Avatar
I do have the 43430 purple HVLP gun, but had wondered about the smallish 1.4 tip for this primer. My paint shop guy confirmed that also, 1.4 tip is small and he reminded me that acetone was ok when I was back in the epoxy stage not when shooting the build primer. So apparently my bubbles were solvent pop .
I picked up the urethane reducer today, and can try my skills at spraying that once I sand off my incorrectly applied primer in all the places on the cab where it will be seen or exposed to the elements. Learning alot on this part of the truck, but I think lessons learned the hard way are the ones you remember the longest!
Baddbob, so I can reduce that much 5-1-2? I am glad to hear it actually because I am sure that will agree more with my 1.4 tip. My paint shop guy told me I could reduce 10%, which I take to be 5-1-0.5 .
Old 11-14-2006, 06:04 PM
302 Z28's Avatar
Acetone is used for polyester primer, urethane reducer is used for urethane primer. Add a little urethane reducer to your mix and it will spray a lot easier and smoother. The 1.4mm tip is not ideal, but it will do the job.
Vince
Old 11-14-2006, 07:08 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
And,
That gun needs a LOT of air to spray right.
Unless you have a 60 gal/5hp,You might want to consider getting the "other" purple gun which is a conventional style requiring higher psi but less cfm.
Could be why the smaller shoots,dash,jambs,pillars turned out good and your really working the air supply for large areas and running out of air. Something to consider.
Mike.
Old 11-15-2006, 12:58 AM
BIGSKY's Avatar
My compressor is 7hp/60 gal, but good idea, I will keep an eye on the tank pressure when spraying. I have kept my gun regulator at 40 lbs. figured more that that would be a bad idea, is that the right thinking?
Sanded all the important areas down tonight to get the improperly mixed primer off, it was a ton of material. I scratched the other areas with scottbrite then wiped it all down. Tomorrow I go at it with the correct reducer and see what I get .
Old 11-15-2006, 05:16 AM
Don Meyer's Avatar
You may want to find a DeVillbus model 7 or knock off for k2 primer. There is a 2.2 nozzel for the purple hvlp gun, but that might be too big for k2.
Don
Old 11-15-2006, 06:52 AM
Bee4Me's Avatar
Cool. Those guns like around 40-45# at the gun regulator so your close on that. Reducing with the urethane will be a big help but you will probbly still have to go a little slow for consistant coverage. Just be sure and do some test shots and after you get that right give it another 1/2 turn on the fluid open which should give you better coverage/speed.
Old 11-15-2006, 11:02 AM
BIGSKY's Avatar
Don
I do have the 2.2 tip for my 43430, but I found that it was just too big, the primer came out like a hose with no pressure.
Hopefully with my mix reduced I can fine tune the gun with the 1.4 on it, up to now I have had all the settings full open to get any kind of good flow.
Old 11-15-2006, 12:08 PM
302 Z28's Avatar
I also have the 2.2mm tip for my 43430 and found it too big. You will find that when you reduce the K36 it will lay down very nice with the 1.4mm tip and it will have a dull sheen to it with very little orange peel.
Vince
Old 11-15-2006, 02:13 PM
BIGSKY's Avatar
Vince
That is exactly what I have been looking forward to, and figured that the 43430 could do that based on its recommendations here.
Old 11-16-2006, 11:50 AM
BIGSKY's Avatar
Mixed my primer correctly with one part urethane reducer [5-1-1] and it came out very nice. I am now excited to shoot the color, because I know my little purple friend can shoot paint correctly, user errors not withstanding .
Old 11-16-2006, 03:38 PM
302 Z28's Avatar
Glad everything worked out good for you. The purple gun can do a superb job, given the chance. It will also do a fairly good job with clear if you jack up the inlet pressure to about 45psi.
Vince
Old 11-16-2006, 04:29 PM
paint
grab a copy of car craftdec 06 at ur crnr store i just learned lots frm article about paint etc orange stang on cover
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
PPG k36 surface primer question Z-Money Pit Body - Exterior 2 03-20-2005 07:54 AM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
