-   -   PPG k36 surface primer question (http://www.hotrodders.com/forum/ppg-k36-surface-primer-question-59980.html)
Z-Money Pit 03-19-2005 08:30 PM
Hello everyone,
I am on my final coat of K36 surface primer and was wondering what grit sandpaper I should use for the final pass before the application of the epoxy sealer that I will be using (the base/clear will have to wait for the warmer weather so I am going to coat it with dp76 for now). I am aware that I will need to sand the epoxy sealer before I move on to the base color. But for now, what should I finish the K36 with.
Thanks again.
Rick WI 03-19-2005 09:53 PM
Final with 600 and leave it alone. When the weather warms clean with wax and grease remover, rescuff and then apply the sealer. I don't think the sealer is needed anyway. A smooth even 600 sanded surface of k36 is fine to put your base over.
302 Z28 03-20-2005 07:54 AM
I agree with the above comments about the epoxy sealer. K36 can be used as a sealer with a different activator.
Vince
