Hotrodders Bulletin Board
#1
PPG k36 surface primer question
Hello everyone,
I am on my final coat of K36 surface primer and was wondering what grit sandpaper I should use for the final pass before the application of the epoxy sealer that I will be using (the base/clear will have to wait for the warmer weather so I am going to coat it with dp76 for now). I am aware that I will need to sand the epoxy sealer before I move on to the base color. But for now, what should I finish the K36 with. Thanks again. |
#2
Final with 600 and leave it alone. When the weather warms clean with wax and grease remover, rescuff and then apply the sealer. I don't think the sealer is needed anyway. A smooth even 600 sanded surface of k36 is fine to put your base over.
#3
I agree with the above comments about the epoxy sealer. K36 can be used as a sealer with a different activator.
Vince |
Back to top |
Similar Threads for: "PPG k36 surface primer question"
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 121 | 05-20-2009 09:12 PM |
| HOK paint over PPG K36??? | dh79 | Body - Exterior | 21 | 03-04-2005 01:51 PM |
| using primer question | AdamZx23 | Body - Exterior | 21 | 02-16-2005 10:53 AM |
| Quickie primer question | Bluepen | Body - Exterior | 1 | 05-21-2003 05:33 PM |
| PPG epoxy primer | mustangguy | Body - Exterior | 2 | 05-18-2003 04:25 PM |
