Ppg Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2006, 08:07 PM
Ppg Question
Can someone tell me what kind of paint PPG DT885 reducer is for urathane, epoxy or what. Someone gave me a case of it about 4 years old & i am not familiar with the ppg stuff
DONZIE
Old 06-28-2006, 08:13 PM
blacklabzeke's Avatar
Acrylic urethane warm temperature reducer .
Old 06-28-2006, 08:31 PM
milo's Avatar
point on positive
It would go into PPG's DBC base color and some of their clearcoats..but not all
Old 06-28-2006, 08:50 PM
You can also use it to reduce epoxy primer. Although the stuff is 4 years old there isn't a shelf life on it and it will work just fine. Slow drying for hotter temps. Bob
Old 06-28-2006, 09:09 PM
302 Z28's Avatar
It reduces DBU, DBC, DCU2002 clear, and several primers.
Vince
Old 06-28-2006, 09:15 PM
DBU basecoat uses a reactive reducer DRR, I haven't used DBU in many years and I don't know if a regular urethane reducer would work. Bob
Old 06-28-2006, 09:17 PM
DT does work in Global's basecoat, primers, and clears and also Omni base, primers, and clears- no problem.
Old 06-29-2006, 07:18 AM
Thanks A Lot Fellows - This Sight Is Awsome !!!
I Am Not Into The Ppg Stuff Cause Of The Local Supplier Being A Pain To Deal With. Would Have Taken Him 2 Hours To Answer My Question I Asked Here. You Know The Kind Of Guy That Takes 15 Minutes To Tell You Good Morning
Old 06-29-2006, 07:58 AM
302 Z28's Avatar
Oops, Bob is correct, sorry for the misinformation .
Vince
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
What are the PPG requirements for their different levels? SilverFocusZX3 Body - Exterior 1 09-13-2005 10:05 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
