Pre 8 3/4 Chrysler rears? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2011, 06:17 PM
One site I have seen said Chrysler only produced on size banjo type rear... 8 3/4. Is this the same rear that is in My '52 meadowbrook and '54 New Yorker? A buddy of mine says they are 8 1/4" and to junk it?? From what i understand the 6 cyl cars had some low gears... like 3.73:1? Can you convert the to disc brake easily? i.e. 86ing the press on drums and retaining the nut type axle? Or should I swap to something else and ditch this rear?
Old 01-28-2011, 06:56 PM
Not sure of the ring gear dia. for them, but I can tell you that a 3.90 ratio was pretty much standard for a 1948 Plymouth. They seem to be a stout rear end, but their drawback was no provision for a parking/emergency brake set-up. The parking brake/emergency brake was accomplished by a drum arrangement on the tailstock of the transmission.
Old 01-29-2011, 12:26 AM
hkestes's Avatar
48 Plymouth Club Coupe
AAJ sells a kit to install discs on the stock Plymouth rear end with the tapered axles.
AAJ Brakes
How strong are these rears? IRS bonuts Suspension - Brakes - Steering 3 09-21-2004 03:03 PM
are they posi rears Sheir-Ron Transmission - Rearend 21 07-19-2003 07:50 PM
web site 4 rears kruzr Transmission - Rearend 0 01-19-2003 06:38 AM
REARS ARI Transmission - Rearend 1 01-04-2002 08:52 PM
rears ramjet1320@msn.com Transmission - Rearend 0 01-04-2002 06:49 AM
