Yes you should be able to get oil to the push rods/rockers. What type oil primer are you using? Is it a home made tool?
Steve
Prime
how long did you run the drill??? I have seen it take 10 to 15 minutes to get oil up and out all the rockers...
what drill are you using??? it needs to run at least 700 rpm and you can not use a cordless because they run out of smoke before your done...If you using one of those 375 rpm heavy duty drills it might take forever... what tool are you using??? Are you using a old distributor???? How much pressure do you have on the gauge???? keith |
Steve |
Im using a pretty good drill, im not sure what its peak rpm is, but its pretty strong, its a bosch. and the tool is one i got from a parts store, it was like 12 bucks, but it has a block off for teh distributor hole.
The aftermarket oil primer I had (Summit) did the same thing because it was not sealing the bottom of the oil galley that feeds the lifters on the passenger side of the block, and the oil was just going right back into the pan. I had to lift the tool until it almost let the oil out on the top side before it would seal the oil galley and build pressure.
oil
71 is correct sometimes you need to lift the tool to get it to prime right , or use 2 gaskets under it if you get tired of holding it up..
how long did you run it??? |
i suppose i just need to be more patient. I usually stop when the dril starts smoking which is like 3-5 minutes into it. Ive only tried about 3 times but they were pretty spread out, like an hour between attempts. ill also try lifting it. thanks for the advice guys
oil
3-5 minutes is probably not enough...
Also have your dad turn the engine over while your running the drill... Keith |
Did you fill the lifters and filter with oil before during assembly with the lifters and at install with the filter? If not it may take a while to fill everything. More than likely, more than the 3 to 5 min. If you time it your 3 to 5 may be less as while standing there smelling your drill it seems a lot longer than it really is.
| t5 swap on pre '65 ford 289 | flamedfordbronco | Transmission - Rearend | 2 | 10-25-2005 05:00 PM |
| pre oiling | gmcmur1945 | Engine | 6 | 01-30-2005 10:49 PM |
| 406 pre ignition problem | 406 ss monte | Engine | 20 | 02-29-2004 11:31 AM |
| Rockers not oiling on 454 | jameson1 | Engine | 1 | 09-20-2003 10:01 PM |
| engine pre oiler | Buffed | Engine | 3 | 12-28-2002 05:56 AM |
