Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pre-oiling a SBC
Old 04-17-2012, 10:19 PM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
you won't get oil in the push rods until you crank the motor.
pull the coil lead off and crank the motor, you will have oil flying all over right away
oil pump floods the lifter gallery and the lifters pump the oil up thru the push rods to the rocker arms
this is why some motors clatter the valve train upon start up, the lifters need to pump up
