Pre Plannning 400 sbc S10 Build
Hi, I recently just bought a 1971 400 2 bolt main Small block chevy, its a complete virgin block. Sad part about the motor is that it has sat for about 3 years, and has taken a beating from kansas weather. Its froze, but the rust is not deep. A hone could easily take out the rust inside of the cylinders. The motor was tooken out of the truck due to a broken piston and just sat and sat. I recently just got a Job at a Nursing home, as a maintennaince worker, and Im kind of just pre planning the build completely. The motor will be rebuilt fairly stock, and Ill just do add ons until I reach my goal. I want the truck to be leaning towards the drag strip, yet still be fairly streetable.
Basic Plan- The vehicle that the motor will be placed in is a a 1986 s10, that weighs 3200lbs empty. Im looking to get around 450-500 horsepower at the motor and hopefully around 375-400 at the wheel. The tranny for the vehicle will be a TH 700r4 with a stall around 3000-4000, servoed out, and the differential gearing will be 4.10s. Im thinking to hit around my goal, that this setup might be in the ballpark. 406 (.03 over 400), a 750 cfm Holley Double pumper. Im not sure of the intake, but Im thinking something around the 2500-6500 rpm range, Maybe a World Motown Intake that makes power from 2500-8500. A summit Capacitive Discharge Ignition Box with a rev limiter set at 6200 RPM. Dart Heads with 215cc Intake 64cc Chamber, 2.08 Intake, 1.8 exhaust. A Comp Cam, 2500-6500 .248/.248 Lift .525/.525. And a set of S10 shorty headers, with 1 1/2 inch primaries. Summit 1.6 Roller rockers. Stock bottom end for now, until I get enough money for all Forged. And a set of Drag radials, ttraction bars, just basic things to get some traction. Do you think this could do high 13s on the 1/4 track ?. WIth 106octane, and a 100hp shot of NOS ?. Anyt tips or advice is greatly aprreciated. Thanks
Pre Planning Build For 400 Small block Chevy
Hmmm, sounds like its gonna be fun to change the plugs......EHhhhhh... Anyways I had a new question, I accidentally pretty much ruined the crank popping two frozen pistons out, the stud tore the hell out of the journals which I foudn out were all ready .020 under. So I looked in Summit, and found that I can get a 400 crank, for $170, external balance. Which uses the 5.565 rods. I noticed the harmonic balancer had a noticable machined groove, which I figured was the external balance, and heres my question, could I replace the crank with the summit crank, and not worry about having it balanced ?, someone from my neighborhood told me that I probably wouldnt have to worry about getting it balanced because they are all the same wieghts, and I figured Maybe...... But im not sure, I dont plan on spinning the motor(406) any over 6000RPM anyways.
you need to get it rebalanced. Just look for a master rebuild kit with all your parts- you'll save money in the long run. There are a few other places that you can cut corners that won't hurt you too badly. If you can afford it going with 5.7" rods and forged pistons is a good idea, but I understand if money is too tight.
This truck should run high 11's on motor. If you are not going to use forged parts skip the whole nitrous idea. Take that money and buy better rotating assembly parts, you can always add the nitrous later if you have a solid bottom end. If the crank is still good, use that but, buy better rods and pistons. |
Yeah, Ive never put a small block into a S10, but Im betting that it would be a little difficult to change the plugs, without fenderwells, Id imagine it would be a little easy... So you think this build could run high 11s on the quarter ? Wow, that was better then I was planning, would stepping up the stall help with the time ?, or would I risk traction loss, Which brings me to another good question, How do you get "decent" or adequate traction in a v8 s10 that has globs of horsepower ? I mean the little 6 banger could tear it loose all over asphault just because theres no weight.
???? Actually, I have an Idea to improve the time, what about, Steppin up my power band from 2500 to 3000Rpm, using the dart heads, with the 230cc intake 64 cc chamber, 4.56 gears, a 4000 stall ? Do you think this setup would improve my time maybe to lower 11s high 10s ?, Im in highschool, and I want to make the truck faily quite, and drag the other kids with the supposive so "******" stangs, vettes, and camoro's, Would this setup be faily close to 500 hp ?, what is some improvements to get to that goal ? I used a calculator and with the 700rh and even with 4.56s it only wraps around 2600rpm at 65, I compared this to my moms Dodge avenger, and at 65 shes already at 2400Rpm, so I think I will use even a higher gear ratio and settle with the 4.56s. ??? Could someone run a desktop Dyno for me ? Thank you Last edited by 396flyby; 10-12-2009 at 11:36 AM. |
Had to add CORVETTE and change "are" to are'NT
Cooling these things is a PIA, forget the fancy radiators and never consider a 4.3 V6 unit. Get a 1970's era Malibu brass/copper unit for the big block motors with A/C. These can be fitted on the stock GM rubber bottom rails by moving them out-board a little. The top can be secured with the upper rubbers rotated around the front with the truck's radiator frame and the radiator's frame drilled for a pair of 1/4 inch machine screws and nylock nuts. The CORVETTE aluminum radiator mike Knell suggests also works well. If you use a long water pump there's only space for a front mounted electric fan (s) which are'NT too effective. A factory fan will just fit on the pump hub and clear the radiator, but does not have space for a thermo cut out. If you convert the engine to a short water pump, you gain enough space for an OEM thermo-fan and stubby shroud, this does a lot for extended idle and low speed cooling Get these two books and follow the recipe plus my notes and you're swap will be fine. Chevrolet S-10 Truck V-8 Conversion Manual http://www.jagsthatrun.com/Pages/Che..._S-10_V-8.html Chevrolet TPI & TBI V8 Engine Swapping http://www.jagsthatrun.com/Pages/Che...I_TBI_V-8.html Bogie Last edited by oldbogie; 10-13-2009 at 12:56 PM. |
Might want to check your engine year all 400's from 1970 -1973 where 4 bolts
Oh, my mistake, I dot know what year exactly, but you are right, its 1974 or later. Does anyone think this setup would be decent for my goals ? Horsepower ?.
Thanks |
Does anyone have an answer ???
Thanks |
A 700R4 is not up to this, to feed 450 -500 horses will require a race prepped rebuild. This transmission has a really deep low, that combined with a 4.10 rear will be tire spin crazy. This is why so many guys look to the 200R4 for a competition transmission as it's low is not so deep. But it really takes building those transmissions with some stout as stock there certainly not up to a V8. Bogie |
I would forget the Sanderson headers, Hedman makes a set with 1 5/8" primaries that are long tubes, and fit all inside the chassis. If you really want a huge amount of info about the V8 S10 swap that will keep you reading for weeks, check out v8s10.org ,
![]() That was the only early 2-bolt I had. I had two other 4-bolt 400's, and one later model 2-bolt, which had the typical "straight" main caps. And for 396flyby, I had a '67 Nova with a 406, "462"-camelbacks(un-ported), 4779 Hollley DP (out-of-the-box jets...untouched), Performer RPM, smaller cam than yours, Muncie (and eventually a powerglide), 4.11-posi, 28-in. slicks, that put the car in the high-11's. Shouldn't be that hard to get 12's or 11's, so long as you can get the tires to bite. Your 1-1/2 primaries on the headers are a little small though. Last edited by a1supersport; 06-02-2010 at 07:33 AM. |
| 400 sbc vs 400 pontiac | Artemis Entreri | Engine | 52 | 09-08-2010 06:17 PM |
| SBC Motor Build | weshova | Engine | 4 | 10-21-2008 10:10 AM |
| Recommend me a build! 400 sbc, 64cc heads | bunni | Engine | 5 | 03-17-2007 08:14 AM |
| 0.060 over 350 sbc or 0.040 over 400 splayed cap sbc | tony350ss | Engine | 4 | 05-17-2003 09:02 PM |
| 400 SBC Balancing and info ? | Brobob | Engine | 8 | 10-31-2002 03:44 PM |
