Pre/post '87 SBC differences? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2005, 08:51 AM
Gearhead forever's Avatar
Motor newb question here.....I'm hearing that there is some differences (heads?) between the pre/post '87 SBC motors. Is there any other differences besides that? "ive got an '87 305 that I was thinking about rebuilding...maybe with vortec heads (??), cam, headers and bigger TBI & manifold. Would camel hump heads be any good for this motor? I did a search, but the sheer number of threads became overwhelming. Thanks for the patience....
Old 02-22-2005, 08:58 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
GM started phasing in different changes then.
One piece rear mains
center bolt valve covers
Center bolts on intake(around Ex Gas crossover) just slightly different angles
blocks machined for roller cams
mech fuel pump mounting pad not machined
and slightly later changing the timing cover.
Your '87 is probably just like the older motors but the center intake bolts are slightly different. Either set of heads you listed will work but the vortec heads need a special intake.
Old 02-22-2005, 09:17 AM
rick458's Avatar
Wookie
Most Edelbrock manifolds come with a Vortec version, as do many other makers
the Vortec heads are a really good deal
http://www.sdpc2000.com/catalog/3539/Modified-Vortec-Cylinder-Heads.htm
the Fast burn heads are very nice as well
http://www.sdpc2000.com/catalog/3129/products/144/Fast-Burn-SB-Chevrolet-Aluminum-Cylinder-Head.htm
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 10:43 AM
87 350 sbc core rally4x4racer Engine 15 09-09-2006 05:56 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 11:12 PM
87 SBC 350 Internal / External balanced?? punk1c5040 Engine 11 03-24-2004 08:12 AM
