Pre-used flywheel bolts ok?
When I mounted the used T56 transmission I just used the enclosed flywheel- and pressure plate bolts.
Torqued according to the LT1 instruction manual and used Loctite thread lock. After that I've been thinking. Should I have used new bolts? A loose flywheel is scary, but on the other hand, if everything is ok, changing the bolts now is a lot of extra work since the transmission is mounted in place. The motor is a 350 cid L05 rebuilt with carb. |
As far as thinking about it after the fact, I did the same thing after I got married the second time. It's been 30 yrs. today so I guess I did the right thing!
Thanks for the answers, by the way!
tom |
some have the dowel, some don't and it AIN'T for locating a externally balanced chevy flywheel... and i can walk out to the shop and look at a 400 w/o a pin |
there ARE no 400's with a 1 piece seal and about the only place i ever see the dowel is in 3/4ton and up stuff i assume it's for somewhat of a drive pin |
i guess i am not sure on the 400 rear mains, But the dowel pin on various crankshafts are there to properly locate the weights on the flywheel to balance the motor, is this that complicated to understand?
| Rant about aftermarket sheetmetal | cyclopsblown34 | Body - Exterior | 27 | 01-28-2010 10:14 AM |
| corvette front clip | rhinz1966 | Body - Exterior | 12 | 01-11-2010 04:57 PM |
| any help ya'l | luvchevs | Body - Exterior | 6 | 01-06-2010 09:35 PM |
| Removing bumper bolts | Slipangle | Body - Exterior | 1 | 07-09-2007 07:56 PM |
| body parts fitting | anyoldchevy | Body - Exterior | 10 | 02-20-2005 09:20 AM |
