Precautions ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2008, 07:42 PM
chevy350_Camd's Avatar
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
Precautions ???
Im planning on putting a 420 horse in a 1978 Monte Carlo, is there any steps I should do, can a car frame like that hold up with that much power.
Do I need to chain the motor down ?. Thanks For Any responses
Old 04-14-2008, 08:23 PM
BORTI's Avatar
BLOWN 357
precaution
That is not an unreasonable amount of HP.You won't have to modify the frame.Its when you get into big inch high torque big blocks that you stand a chance of twisting the frame.I recommend some good polyurethane motor mounts.
Old 04-15-2008, 10:52 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You should be OK...go ahead and put it in there.
Precautions? Installing Polyuerethane bushings topdogger Suspension - Brakes - Steering 12 02-02-2007 08:18 PM
precautions for turbo 350 that sat unused for 1 year? 5.7s10 Transmission - Rearend 3 01-07-2006 02:06 PM
An interesting article on welding procedures CrashFarmer2 Hotrodders' Lounge 3 08-14-2004 05:17 PM
