Predator carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 08:10 PM
spinn's Avatar
Predator carb
Looking at my engines , my paths crossed every carb type, except.
440 with 800 AVS/ or 750 MightDemonDP holleyStMa SP
323 (318) with holley 600 VS EdelbrockStMa SP
305 Vortec QJet fed Performer DP
For a kick my freind has a Predator carb. Claims it can work really well on the street. No Jets, rods, pump cams, idle system , to tune. You hold the gas pedal where you want the idle. Floor it , hope for the best ?
Worth a go, or 80's artwork.
Old 01-20-2011, 08:24 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
here are some search results for "predator carbs"
lots and lots of reading
Old 01-21-2011, 08:07 AM
DoubleVision's Avatar
You maybe able to still get a idle circuit for it. I wouldn`t run it on the street without a idle circuit as the idle will be the lowest the carb can flow, which is usally around 1500 RPM or so.
Old 01-21-2011, 08:17 AM
& matts38chev
i have one that may never get used
to be honest i kinda forgot i have it until i just seen your post
predator carb. racer57 Engine 2 11-24-2008 01:46 PM
Predator Carb Help xxllmm4 Engine 7 08-31-2007 01:13 PM
Predator carb ishkabibble625 Engine 4 01-03-2007 01:37 PM
Predator Carb HELP banbug Engine 3 08-30-2006 09:43 PM
Predator Carb Double J Engine 2 06-28-2003 02:15 PM
