Predator Carb Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2010, 06:37 PM
Predator Carb Help
I have a big block Chevy Predator Carb and no part number. Only patent number; 4283355. Anyone know if I can use it on a 350 GM? Will that work or can it be re-jetted down? Thanks for the feedback
Old 07-18-2010, 06:44 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Try this http://www.predatorcarb.com/home.html
You can use it on a 350, built .
Old 07-20-2010, 07:42 PM
Because this is MORE of a ENGINE question than General Rodding .. ... As a moderator I am moving this thread to the ENGINE area where hopefully you will receive more views and get answers from members who are more " engine orientated ... "
Deuce ... MODERATOR
Old 07-20-2010, 07:51 PM
F-BIRD'88's Avatar
Yada Yada Yada
The only good use for these carbs is as a anchor.
Tie it to a rope and if say your brakes on your car suddenly fail as you go screaming down a hill, pitch the carb on a rope out the window.
Maybe it will snag on something and save your ***.
Old 07-20-2010, 08:13 PM
WDCreech's Avatar
Grumpy Old Goat Herder
F-BIRD'88, You are so full of feces that it's running out of your ears.With only three settings, there is no carburater that is easier to tune than a Preditor. They work on big engines, or small engines. You can probably get better performance from a Holley or Q-Jet, but they take more finesse to get there.
Old 10-10-2010, 01:25 PM
scapegoat's Avatar
Hey these carbs are awesome! I just put one on my carbed 6.0 LS motor. Absolutely instant throttle response! The best responding carb i have ever used. I had a holley HP before this.
