predator carb help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2012, 05:01 PM
predator carb help
i am looking to buy a predator carb.the problem is there is no spot to hook up the tv cable from tranny.any suggestions?
Old 08-03-2012, 05:48 PM
vinniekq2's Avatar
Ive had a predator carb sitting in my shop since the late 70s.I think a few of us tried it for a day.are you sure you want one?
Old 08-03-2012, 07:47 PM
carb help
yes.i do alot of four wheeling.but my tranny is a 700r4 from TCI. and it has an tv cable.
Old 08-03-2012, 08:32 PM
spinn's Avatar
Try edelbrock 1484 throttle arm adapter and a 8018 tv stud. It is adaptable to alot of carbs.
However I would avoid a predator carb for any use.
Old 08-03-2012, 09:13 PM
vinniekq2's Avatar
yay,spin agreed with me this time,lol.I knew we could find common ground.BTW spin,I actually like your truck.I had one the same colours and similar year.
Old 08-03-2012, 10:24 PM
carb help
i figure its like ford and chevy. some people love predators and some hate them.todays predators you can get one with an idle circuit.and i find lots of people mess with the adjustments to much as if they were regular carbs,instead of learning how properly.thanks for the input.
Old 08-03-2012, 11:45 PM
Summit, Jegs, Edelbrock, all sell throttle cable brackets the will hold both your throttle and TV cable, plus adjustable arms are available to attach a TV stud to the right position on your throttle arm. Its a little bit of fabrication, but shouldnt be hard at all. Just get the angle of the cable correct so its pull properly.
Predator carb spinn Engine 3 01-21-2011 08:17 AM
Predator Carb Help xxllmm4 Engine 7 08-31-2007 01:13 PM
Predator carb ishkabibble625 Engine 4 01-03-2007 01:37 PM
Predator Carb HELP banbug Engine 3 08-30-2006 09:43 PM
Predator Carb Double J Engine 2 06-28-2003 02:15 PM
