Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - predator carb v.s. holley 750 dyno chart
Old 06-29-2006, 08:48 AM
chevelle4542speed chevelle4542speed is offline
this carb will fit any thing from 300 c.i. to 500 c.i , flows any where from 390 cfm to 930 cfm , it only gives what the engine needs. your never over flowed or under flowed at any rpm.and if you did any motor work like bigger heads , cam that sort of stuff you dont have to buy a bigger carb. i really think that this is the best carb out there..
hot rod magizine performed the test out of the box for both.
