predator carb v.s. holley 750 dyno chart - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2006, 08:11 AM
just thought you might like to see this for those that are not sure about he carb.
Name:	red snaper 012.jpg
Old 06-29-2006, 08:48 AM
this carb will fit any thing from 300 c.i. to 500 c.i , flows any where from 390 cfm to 930 cfm , it only gives what the engine needs. your never over flowed or under flowed at any rpm.and if you did any motor work like bigger heads , cam that sort of stuff you dont have to buy a bigger carb. i really think that this is the best carb out there..
hot rod magizine performed the test out of the box for both.
Old 06-29-2006, 09:17 AM
maybe the worst performing carb
yeah right ! i strongly disagree.
i never got them to perform, on anything.
the test states out of the box predator vs out of the box 750 double pumper. also that it is better, because it has fewer peices and is easier to tune ?
that test data is useless.
Old 06-29-2006, 09:35 AM
mstngjoe's Avatar
Who conducted the testing? What was the engine combo? What kind of dyno?
Old 06-29-2006, 10:13 AM
it doesnt say what the specs on the motor are. looks to me to be a mild combo, doesnt say. for the first guy have you ever had one that worked properly , the first ones had a problem on the acclerator pump it had problems like leaking . but they have fixed that problem now witha duel diaphram acc pump.
Old 06-29-2006, 10:21 AM
well does the holley fit that many diffrent sizes 300 to 500 c.i. flows 390 cfm to 930 cfm , i dont think the holley can do that , never under or over carburated . this carb is not for the daily driver, you can but with 12.5 to 13.1 air/fuel ratio gas mileage sucks
Old 06-29-2006, 10:23 AM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
What's your point, Chevelle? Did you come across one and thinking of buying it? Summit doesn't carry 'em anymore, don't know if they are still in biz. It's pretty easy to match a Carter, Demon, Edelbrock, or Holley to any combo.
Old 06-29-2006, 11:19 AM
If they are so great , why are there not so many around these days?
Old 06-29-2006, 11:27 AM
if thats what you like, try it. then let us know. there was a guy back in my high school that loved em, always listened to skid row...said things like ,"and ill put dual predators on it".
if you have little carb tunning expirence, i recommend a edelbrock or holley with vacuum secondaries. the reason so many people use them is that they work, very, very well.
bigbadbowtie's Avatar
Bottle Fed
You also have to ask WHAT holley 750 did they compare. Was it an all out race carb Holley Hp series like the Predator or a streeter style holley with a choke,choke horn ect ect.
I have never seen one at the track but that does not mean they don't work??
Still in business..... http://www.predatorcarb.com/home.html
Old 06-29-2006, 11:28 AM
Last journal entry: PICTURE TEST
carb
It's like numbers off a flow bench.... looks good in print, but the car can't fall out of a tree with one on!!!!
Try this, buy one put it on your car and race it, get it tuned all you can get... I'll show up with an out of the box holley and smoke your best time by 3 tenth!!!!!at least...
Keith
Old 06-29-2006, 12:16 PM
well i do have one , the motor i have only has 5 pounds of vacum i had a holley with secondary vacs on it , got no idle with it , i know you can drill holes in it stuff like that. it also took to long for the secondary to kick in, i know i could of got a mach sec but i didnt want too. i tryied this predator and its awsome. throttle response is the best ever. it curied my idle problems. why you dont see them a lot is becuase of no advertisment and some people just dont understand them. scared to try new things.
Old 06-29-2006, 12:17 PM
Keith
your a pretty funny guy!!!
Old 06-29-2006, 12:40 PM
keep telling yourself that if it makes you feel better.
Old 06-29-2006, 12:53 PM
well do you se any advertisment on them at all.
Holley 750 Carb Leak tweeter400 Engine 25 02-17-2006 08:42 AM
Jet sizes for a 750 holley junkyardjeff Engine 4 09-14-2005 09:13 PM
Holley 750 vac sec Carb onecoomofo Engine 6 05-02-2004 04:54 PM
Holley 650 DP Mec Sec or 750 Vac Sec DTL504 Engine 7 12-29-2003 04:25 PM
600 cfm holley vs 750 cfm holley 85 regal Engine 7 11-27-2002 06:25 PM
