The primary factors are being overlooked here.
The max lift of the cam is irrelevent. When the valve are at peak opening the piston is more than half way down the bore. The valve opening at and near TDC overlap is the critical factor. The more duration and overlap the more critical. Piston valve relief depth and location--valve centerline locations. non stock geometry must always be checked. larger than typical valves must be checked for radial clearance of the valve relief too. need the Complete camshaft specs. or camshaft part number. Why "worry" when you can check VTP clearance and not worry? You or somebody is going to check-verify VTP clearance on hte assembled engine ,,,right.... Last edited by F-BIRD'88; 01-23-2013 at 08:54 AM. |
| The Following User Says Thank You to F-BIRD'88 For This Useful Post: | ||
0trbo4myCHEVUICK (01-23-2013) | ||
Yes me or somebody will be checking clearance when ll is put together. The short block is at the mchine shop for a few weeks so im just brainstorming on stuff to keep my brain from exploding with anxiety. The camshaft is voodoo- •Advertised Duration (Int/Exh): 270/278 •Duration @ .050 (Int/Exh): 221/229 •Gross Valve Lift (Int/Exh): .515/.530 •LSA/ICL: 112/106 •Valve Lash (Int/Exh): Hyd/Hyd •RPM Range: 1800-5800 •Includes: Cam Only Part Number: 20080721 Previoius Part Number: 60121 |
The decking of the heads and block had me worried. Aparrantly I was worried about the wrong variables. |
On hyd and solid flat tappet stuff with stock like 23° heads I start looking @ VTP clearance
potential issues when the cam gets bigger than 244@.050". And then always check before running. By you checking yours, you can get some idea of clearance relative to potential future cam swaps with larger cams. Rollers start looking when the cam duration gets to 238@.050" Always check actual VTP clearance. Can be a world of expensive grief if you don't. |
I have discussed this subject several times over the years with my engine builder in Dallas. He has been building drag race, circle track and high performance street engines since 1968. He told me that a SB Chevy with flat top pistons will have .100" clearance with 2.02" intake valves and a camshaft spec at 240 deg. duration @ .050", .550" valve lift, 112 deg. LCA if the valve action is kept under control.
In order to maintain control of the valv train, use appropriate valve spring pressure for the camshaft being used in order to prevent valve float. Valve lift from .500" to .550" should use short or reduced travel hydraulic lifters and valve springs with a minimum 130 lb. seat pressure and 340 lb. open pressure. That kind of spring pressure is a problem with flat tappet camshafts because of the lack of ZDDP in motor oils. Therefore, the use of a hydraulic roller cam should be considered. With any high performance camshaft, aftermarket short or reduced travel hydraulic roller or flat tappet lifters are preferred. Those lifters have a pre-load setting of .005" and cannot pump and float the valves because the lifters have nowhere to pump up to. Most cam companies have limited travel lifters for serious high performance engines using hydraulic camshafts. Example: Chevrolet V8 engines Comp Cams 858 Pro-Magnum Flat tappet hydraulic .050" total travel .005" pre-load. Full roller rocker arms must be used. Last edited by MouseFink; 01-23-2013 at 11:54 AM. |
| The Following User Says Thank You to MouseFink For This Useful Post: | ||
| The Following User Says Thank You to ap72 For This Useful Post: | ||
While you have some time, get your head wrapped around this tutorial from Isky.....
ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters |
| The Following User Says Thank You to techinspector1 For This Useful Post: | ||
Roller camshafts with similar spec and valve springs with similar pressure need short or reduced travel lifters to maintain valve control at high RPM.
Never use hydraulic roller lifters that were used in Chevrolet engines with a net-lash (non-adjustable) valve train. The lifters in those engines are AC Delco HL-105 (GM 5234670) . Those lifters have .237" total travel and will loft over the return flank of the cam lobes, collapse and reduce valve lift by .119", pump up and float the valves between 4300 - 4800 RPM, with disastrous results. The best hydraulic roller lifters to use with a camshaft with more than .500" valve lift is: Comp Cams 875 Pro-Magnum - Reduced Travel - restricted oiling Comp Cams 15850 Race - Short travel - restricted oiling - REM coated - HD retainer clip .005" pre-load .050" total travel Must use full roller rocker arms. LS7 lifters AC Delco HL-124 (GM 12499425) .166" total travel .082" pre-load I do not know how those react with high lift camshafts and high load valve springs How much valve lift doe a LS7 engine have? I think it is .561" I / .557" E with 1.7 rockers LS7 valve spring pressure: 108 lb. seat pressure at 1.750" assembled height 296 lb. open pressure at .500" valve lift Last edited by MouseFink; 01-23-2013 at 01:38 PM. |
Well thats a real shame isent it?
Thought they would be fine. Chevrolet Performance 12371042 Chevrolet Performance Roller Lifter Kit These are the ones I bought. Those are the ones your talking about? |
Latest specifications for LS 7 beehive valve springs:
AC Delco HL-124 GM-12499425 2.313" free length 1.960" installed height 101 lb. @ 1.960" seat pressure 310 lb. @ 1.370" open pressure 1.085" coil bind 354 lb/in. rate |
AC Delco HL-123 (GM-17120735) LT1, LT4 engines L30, L31 Vortec truck engines .060" pre-load .120" total travel |
| valve to piston clearance | 1966 f100 rod | Engine | 3 | 02-23-2012 10:02 PM |
| valve/piston clearance | chevy fan G | Engine | 3 | 09-06-2011 01:08 PM |
| Valve/Piston Clearance | JohnyR17 | Engine | 2 | 02-20-2008 07:27 PM |
| piston to valve clearance. | 85 regal | Engine | 1 | 04-13-2004 08:09 PM |
| valve to piston clearance | Stinky | Engine | 5 | 06-13-2003 11:32 PM |
