preditor carb peice of *@#~! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2006, 05:07 PM
nitro_baller4692's Avatar
floppers forever
my buddy has a predator carb street version with idle circuit.he tells me he was trying to tune it and now it is popping threw the carb when you try to give it gas.by the way he lives in Michigan.
anyway does anyone know were the base setting are for this carb?he said there is two screws on the carb one for idle mixture and and one for main fuel metering.
i have no idea what he adjusted but he said he turned the big screw and it started to pop but he was and did not pay attention as to how many turns he moved it.
the site did not tell me nothing about this.http://www.predatorcarb.com/home.html
any help would be great i hate trying to fix something over the phone.
thanks for any help!
Old 11-14-2006, 05:58 PM
woodz428's Avatar
Troll Hunter
I have no experience but have been intrigued by the carb since it was introduced a couple decades ago as a Kendig. It uses a similar metering system as the motorcycle carbs that I have volumes of experience with. You might try a local guy that is good with performance motorcycle carbs. I mean someone that has had experience since the 60s since the newer ones are somewhat different. If he gets fed up, I may be interested if he wants to sell.
Old 11-14-2006, 06:04 PM
floppers forever
i'll tell him thank for the info,i told him to get rid of it and get a holley.
Old 11-14-2006, 06:09 PM
Wiki Edits: 31
Preditors are far superior to Holleys, he might have got a bad carb. having the variable CFM is really what makes the carb a good setup
Old 11-14-2006, 07:38 PM
floppers forever
yeah when the truck was here in illinois we had it running great nice throttle responce,i don't know what or why he was making so many adjustments.
by the way it's a 1934 ford pickup chopped and channeled with a 351w 385hp crate motor with aluminum heads,c4 trans,9'' rear end,4-link,4.11 gear.
Old 11-15-2006, 11:19 PM
camaroman7d's Avatar
You might want to try to PM or E-mail the guy that staps buy here. I think his screename was/is "predator carb guru" He really seemed to know those carbs.
Old 11-16-2006, 08:29 AM
floppers forever
thanks camaroman.
Old 11-18-2006, 05:01 PM
predator carb guru's Avatar
Mark Goulette
been a while since i've been online guys, but i'm still here. if anybody has any questions regarding predator carbs, please feel free to email me at my home email: goulette@gci.net.
biggest thing to remember about tuning a predator, is that you can't tune them like a holley!!! they work completely different than a regular carb, and therefore require a different tuning approach!!!
x frame to a one peice driveshaft BRES Transmission - Rearend 0 09-29-2006 07:16 PM
one peice door glass 59 Chev P/U Nowthen50 Body - Exterior 2 07-26-2005 09:30 PM
two peice driveshaft rules KLRS10 Transmission - Rearend 4 03-14-2004 02:02 PM
Ed roth fans own a peice of history, I guess. bonuts Hotrodders' Lounge 6 06-29-2003 09:02 PM
WHY LET A CLASSIC PEICE OF HOTROD HISTORY RUST TO DEATH 59 FORD Hotrodders' Lounge 20 01-13-2003 06:30 PM
