prep for epoxy? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2008, 08:07 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
prep for epoxy?
Would like to shoot epoxy this morning, but need some advice.
Entire body is covered in Slick Sand (sprayable polyester filler) and blocked smooth with 400 grit. I don't have any tack cloths, and I know not to put any water on it, so how should I clean it before spraying?
Mainly concerned about my hand prints that have to be all over it from several days of sanding.
Old 06-15-2008, 09:40 AM
A waterborne wax and grease remover will do just fine, or even a 50/50 mix of isopropyl/water will also work fine. Spray it on and wipe it off.
Metal prep prior to epoxy Dan O. Body - Exterior 1 05-17-2008 04:46 AM
Metal Prep? Silverback Body - Exterior 2 03-21-2007 06:00 PM
Frame prep. and coating on 89' chevy p/u Hazard Body - Exterior 3 03-27-2005 08:46 AM
NOS fender prep ? mark2002 Body - Exterior 0 08-19-2003 09:43 AM
metal prep Busted Knuckles Body - Exterior 10 12-10-2002 11:00 AM
