preparing for adhesive - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2007, 05:56 PM
I have only used adhesive on a couple of small panels on the INSIDE of fenders (to provide backing when filling small rust holes). Now I need to repair a large rusted area, about 4 inches by 2 feet. all across the bottom of a 48 ford truck rear fender. I have made the repair panel but have not cut anything on the original fender. The directions with the adhesive DURAMIX FROM 3M say "do not use a butt joint". Question: What kind of joint should I use? 3m does not provide any diagrams or very clear instructions.
I have used but joints with welded repair panels but I am not sure how to proceed now.
Old 03-30-2007, 07:09 PM
You would most likely have to use a lap joint. Just curious,,,how come you aren't just welding it in?
Old 03-30-2007, 08:17 PM
adhesives
thanks for the responce, statutory grape.
i'm a lusy welder.
Old 03-30-2007, 09:20 PM
Most adhesives call for a 3/4" or 1" lap joint, make sure you have the metal surface ground clean and also make sure the piece fits well before bonding it on. The Fusor website has some good instructions for reference.
Old 03-31-2007, 05:16 AM
adhesive
thanks BadBob
i'll follow your recommendations,
Old 03-31-2007, 08:21 AM
Here is a more detailed bulletin from GM on using the adhesive that could be of help.
Old 03-31-2007, 03:34 PM
Adhesives
thanks martinsr
I bookmarked the gm article.
Help preparing body for winter hot_rod_kid Body - Exterior 11 10-10-2006 04:17 PM
Preparing valve covers Jake_Dragon Engine 2 07-30-2005 07:34 PM
Preparing for a project Dreadlord General Rodding Tech 13 12-28-2004 05:28 PM
Preparing for War!!!!! Kevin45 Hotrodders' Lounge 18 03-13-2003 06:27 AM
preparing the power johnsongrass1 Engine 4 12-15-2002 06:50 AM
