Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Preparing rust for paint
Old 01-30-2013, 04:43 AM
Chevymon Chevymon is offline
Originally Posted by thinwhiteduke View Post
Sandblast it, you need clean, 'unadulterated' metal...
Duke
Media blasting is the only way to make it last, wire brushing polishes the rust and hides it. And urine is acidic so you need epoxy primer and a good urethane top coat to stand up to the acid. If you go quick and cheap then a cheap repair is all you will get.
