preping a roof for a vinyal top..please help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2007, 11:24 AM
Hey guys, does anyone know a good way to prepare the roof of my roadrunner for a new vinal top? It currently has surface rust and glue(old top) on it. Id imagine it needs sandblasted or scraped, and I was thinking a rust killer or some kind of paint or primer?? Please any good proven ideas welcome. (I dont have alot of cash so I need something thatll work but not something for a show car.)
Old 05-09-2007, 11:44 AM
302 Z28's Avatar
Remove all old glue and rust to bare metal. repair any rust holes. Wipe down with a good wax and grease remover. Apply a few good coats of Southern Polyurethane self etching epoxy primer following application instructions. Apply an even coat of DAP Landau Top Adhesive to both the top and vinyl. Allow sufficient time for the contact adhesive to dry and apply the vinyl to the top.
SPI epoxy is without a doubt the best epoxy primer on the market at the most competitive price.
Vince
Old 05-09-2007, 01:21 PM
Listen to Vince, he's right on IMO. Sometimes I shoot a couple coats of urethane singlestage over the epoxy but it really isn't needed as the epoxy will provide all the corrosion resistance you'll need.
Old 05-09-2007, 01:38 PM
39Hemi's Avatar
When I was installing Vinyl tops many years ago once the top was prepped I would drape the top over the roof making sure it was centered, then I would fold it back to expose either the right or left side of the car's roof. With the top folded back I could apply glue to one side of the roof and one side of the top and then once the glue was set carefully work the top back down over the glue. With one side glued down I'd then fold it back the other way and apply the glue to the other half. If you apply glue to all of the roof and all of the top you will have a monster that is impossible to deal with, once the two glued surfaces meet there is no repositioning so work carefully so you don't trap any wrinkles.
Old 05-09-2007, 03:20 PM
302 Z28's Avatar
[QUOTE=39Hemi]When I was installing Vinyl tops many years ago once the top was prepped I would drape the top over the roof making sure it was centered, QUOTE]
Excellent method
Vince
Old 05-10-2007, 09:37 AM
how bout a grind n seal with por 15 then add the vinal roof?
Hey guys my roof is a little rusty...how bout if I grind it then seal it with por 15? Will this keep corosion (rust) away?
Old 05-10-2007, 09:47 AM
302 Z28's Avatar
If your roof is just a little rusty I think you would be better off just sanding it all off and coating it with SPI epoxy.
Vince
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
metalshaping and panel replacement '40 Willys roof Randy Ferguson Body - Exterior 18 11-26-2005 09:00 PM
best paint/ prep to put under a vinyl top novajohnb Body - Exterior 1 09-05-2002 07:16 PM
